Old 05-19-2020, 06:42 PM   #4
Russ.W.
Russ.W.'s Avatar
Lightbulb Re: ECE drop spindle disc conversion instructions? 67 C10
Originally Posted by TruDom View Post
i'll look when i get home. but i do remember playing with the pads a bit. slop will come out of it with fluid in the brake caliper.
I think you might have the pads switched though. the holed pad might go on the inside with the clip. looks like there is a metal bushing thing for it to sit on in the caliper picture.
sidenote: one of my bleed holes wasn't completely punched out from the metal casting and it took me forever to find the issue on why the caliper wouldnt bleed. As it looked normal with the bleed valve on.
Thanks for the reply. I‘ll double check the pads today. They are specific fit - inner & outer pads can’t be accidentally be placed on the wrong side of the Caliper.
However, there is no left/right markings on the pads, so maybe the pads I have on this right-side Caliper actually go on the left side of the truck.
Will check it out.
