Still Green but learning
Window channel
I changed the vertical window channel a while back to stop rattling, but the window frame is digging into it and shredded it. This also hangs the window up, puts stress on the regulator and won't let the window go all the way up.
What am I missing? I left the channel in the truck and used a small metal scraper through the metal channel. Then put some of the black goo on it and pushed it in. What am I doing wrong? Did I just buy something that we're too thick? Any tips would be appreciated
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
All about them K’s
![]() Join Date: Jun 2014
Re: Window channel
This is what I ran into when I put my new precision division bar felts in. It sounds like maybe you’ve got the same problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=805892
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#3 | |
Re: Window channel
All about them K’s
Re: Window channel
Yeah the doors will have to come back apart. I trimmed the corners on mine with a die grinder. It will take longer to take it apart and put it back together than it will to fix the problem.
Re: Window channel
My rubber tape at the bottom of the window is cracking, did you replace it with anything? I am cant find anything the right thickness, I am thinking of getting a tire inner tube and cutting it maybe using a little silicone for adhesive becuase the window has been slipping out.
![]() Join Date: Sep 2005
Re: Window channel
U can buy window urethane at advance auto it will be stronger then rtv
#7 | |
All about them K’s
Re: Window channel
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Window channel
A local auto glass shop may have the setting tape you need and some non-pickup aftermarket suppliers sell it as well.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Window channel
Didn't think of that! I know just the guy
Re: Window channel
My glass guy said he doesnt replace the worn rubber anymore because they are hard to find and all different sizes (for different vehicles) now he runs window urethane in the channel effectively gluing the window directly in. Thoughts?
Carpe manana
Re: Window channel
Sounds like he’s taking the easy way out to me. Not that it won’t get that job done but what happens if/when the glass needs replacing? Digging out the sealant wouldn’t be fun especially from a vent window.
Re: Window channel
This is the main window, not the vent one... not that / that matters. I went out into the shop after talking to him, I think I am going to leave the old hardened one in there and use the black weatherstrip stuff to give it a little extra grip and call it a day.
![]() Join Date: Feb 2010
Re: Window channel
I just did this last week! Here's a hint, go to your local glass shop if they are decent humans they will give you a partial left over tube of urethane. Tear it apart, trim a little off the front of the channel and then glue that sucker back in place. I let it sit overnight then reinstalled everything. Works great now!
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
#14 | |
Re: Window channel
