Old 03-06-2021, 04:16 AM   #1
Accelo
Accelo's Avatar
Dissembling a tilt column
I have been unable to get the tilt column apart. See attached picture.
The round tin cover is supposed to come off. Some say to used a slide hammer to assist. Unsure what is going on but it's not moving. The service manual shows tool j-22708. It's a puller that locks onto the outer lip for removing the housing.
Anybody had this issue before? If so, how did they solve the issue. I know parts are difficult to come by for the tilt columns and don't want to damage any parts.
Accelo is offline   Reply With Quote
Old 03-06-2021, 09:59 AM   #2
70shortfleet
70shortfleet's Avatar
Re: Dissembling a tilt column
The j-22708 tool makes it soo much easier to remove the upper housing but if you don't have that tool, take a flat screwdriver and lightly tap around the bottom perimeter. It could damage the bottom edge slightly but sand it down and you should be ok
70shortfleet is offline   Reply With Quote
Old 03-06-2021, 12:25 PM   #3
Getter-Done
Getter-Done's Avatar
The tool is not that expensive.
I am always looking for a excuse to buy a tool
Here's a Link: https://www.amazon.com/Autocraft-Ste...ts_id=15708991
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 03-06-2021, 12:47 PM   #4
70shortfleet
That's not the correct tool for removing the upper housing
Old 03-06-2021, 12:47 PM   #5
Accelo
Accelo's Avatar
The link is for a lock plate removal tool.
They do look similar though.
The 72 columns don't incorporate a lock plate.
I do appreciate you looking for me.
I have attempted to tap on the bottom of the sleeve and prying on the lip. I am to the point if I do it any harder I will damage the sleeve.
I will attempt to make a tool that can grab a larger area of the lip.
I did manage to get the turn signal switch out past the sleeve. I believe it was designed to have the sleeve pulled first, then the switch. Very difficult to get past the rolled edge of the sleeve without damaging the switch. However, I now have unfettered access to the lip. What should be a simple job is turning into a PITA.
I did find another posting using google and the tool number;
http://67-72chevytrucks.com/vboard/s...d.php?t=558375
It gave me some ideas for building a tool.
I am also going to tap around the base with a piece of plastic and a hammer and see if that helps.
Rick
Old 03-06-2021, 01:11 PM   #6
Getter-Done
I learned something today.
Is it like this one?
Link: https://www.ebay.ca/itm/KENT-MOORE-J...8AAOSwCtJaWF0z
84 Chevy K-20
Old 03-06-2021, 02:00 PM   #7
custom10nut
custom10nut's Avatar
Sub’d for later reference
custom10nut is offline   Reply With Quote
Old 03-06-2021, 02:56 PM   #8
70shortfleet
I use Kent Moore J-22598
Old 03-06-2021, 02:59 PM   #9
Accelo
Accelo's Avatar
The puller on eBay is similar to the factory puller. I believe the jaws are too long and possibly it is missing the legs to catch the inner lip.
Update;
I did get it off without damage. I used a three jaw puller with the jaws reversed. Still wouldn't pull it by itself.
However, with some tapping and tightening and some more tapping and some more tightening of the puller it finally came off.
It would be extremely easy to damage the lip with too much force on the puller.
Some crud and a little rust was holding it tight.
Here is a pictures of the process;
Old 07-26-2023, 12:47 PM   #10
ron350
ron350's Avatar
I know this is a old thread but does anyone know where i can find a kent Moore J-22708 or a J-22598?
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 07-26-2023, 01:18 PM   #11
pjmoreland
pjmoreland's Avatar
About 20 years ago, when I had access to a machine shop at work, I made this puller. I tapped the large hole in the middle to fit the threaded shaft from my steering wheel puller. I don't know what I did with this thing though because I haven't seen it anywhere in years. I've attached the crude detail drawings for the components.
pjmoreland is offline   Reply With Quote
Old 07-26-2023, 01:38 PM   #12
ron350
ron350's Avatar
Pjmoreland thank you very much for taking the time to post all of this. I wish i knew someone who worked at a machine shop.
Old 07-27-2023, 08:01 AM   #13
clay68c10
clay68c10's Avatar
I used a 3 jaw puller and cut a groove in the jaws to engage the rolled edge.
It works well, but you will probably need to do a little re-shaping after use. These collars have been on for a long time and don't remove easily.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-03-2023, 02:09 AM   #14
Accelo
Accelo's Avatar
I have both tools.
PM me and possibly we can work out something.
I don't want to sell them at this time.
Old 08-21-2023, 01:05 PM   #15
ron350
ron350's Avatar
Accelo do you have a Kent Moore J-22598 you are willing to sell or lease?
Old 08-21-2023, 07:05 PM   #16
Accelo
Accelo's Avatar
is this the tool you are looking for?
I paid $125 for it. I know is nutty on the price but so is the column piece if you screw it up. I also the column disassembly / assembly tool you need.
If you want to use them here is the best I can do.
Send me $220. I will use the $20 to ship the parts.
When you are done send them back and I will return your $200.
If interested PM me.
Cheers.
Old 08-21-2023, 08:05 PM   #17
ron350
ron350's Avatar
My friend has a 1968 Cadillac with a telescoping column that requires a J-22598 and a J-2165 slide hammer. On this column there is nothing to push against because of the telescoping feature.
Old 08-21-2023, 09:44 PM   #18
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Looks like a different brand but same-ish part number on ebay for the slide hammer??
https://www.ebay.com/itm/166181733370
NEW TRK TRACTOR 8X6 ALLISON TRANSMISSION SLIDE HAMMER J-6125-1B 5120-01-112-2165
Perhaps ask the seller some Qs about it?
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-27-2023, 02:15 AM   #19
pjmoreland
pjmoreland's Avatar
I have a tilt column to rebuild, so I made a plate that can be slipped into the top of the column for pulling off the cover with a steering wheel puller. The plate has an outer diameter of approximately 3-3/4", although I had to grind it down slowly until it would fit in. The cover came off easily, and there was zero deformation of the lip on the cover.
Old 09-27-2023, 07:18 AM   #20
D.B
D.B's Avatar
PJ, have you thought about making and selling this tool. You do nice work and there are some here that may buy one of these tools from you.
D.B is offline   Reply With Quote
Old 09-27-2023, 08:39 AM   #21
70shortfleet
pj, would your plate work if the turn signal switch is in the column?
Old 09-27-2023, 10:17 AM   #22
pjmoreland
pjmoreland's Avatar
That's an interesting idea.
Old 09-27-2023, 10:23 AM   #23
pjmoreland
pjmoreland's Avatar
No, because it has to go in at an angle to clear the lip on the cover. That's definitely a problem if the turn signal switch is the style that has a red hazard knob that cannot be removed. If the switch is the original tilt style with a removable hazard knob, then the switch can be pulled out to make room for the tool. You have a lot of experience with tilt columns. Do they usually have the removable knob?
Old 09-27-2023, 10:47 AM   #24
70shortfleet
Yes
Old 09-27-2023, 04:07 PM   #25
67sss
67sss's Avatar
knob should have a screw in it.
67sss is offline   Reply With Quote
