Old 06-25-2021, 08:27 PM   #1
Asshat
Asshat's Avatar
Under-bed gas tank without removing the bed or rails?
I was wondering if it is possible to install an aftermarket tank, or one from another vehicle under the bed, and not have to remove any rails. There's gotta be someone that has done this, I hope.
My plan would be to do the side fill, not the in-bed fill.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 06-26-2021, 02:03 AM   #2
SOON2BLAZE
SOON2BLAZE's Avatar
Re: Under-bed gas tank without removing the bed or rails?
The Camoro gas tank FAQ is what you seek
SOON2BLAZE is offline   Reply With Quote
Old 06-26-2021, 02:36 AM   #3
Asshat
Asshat's Avatar
Is this it?
https://67-72chevytrucks.com/vboard/...o+gas+tank+faq
292, 4-speed
Old 06-26-2021, 09:01 AM   #4
Clyde65
Clyde65's Avatar
A Boyd’s attaches under the frame rails
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-26-2021, 12:15 PM   #5
Asshat
Asshat's Avatar
I checked out the Camaro tank; doesn’t look too bad. However, my bumper doesn’t have the license plate in the middle, I would have to modify it or get a different bumper.
I think I’ll just leave it for now, just wish I could get my gas gauge to work. I tried the resistor trick, but it still doesn’t read right.
292, 4-speed
Old 06-26-2021, 10:51 PM   #6
MT65
This is the tank I had made to mount between the last two crossmembers in the frame, side fill
MT65 is offline   Reply With Quote
Old 06-26-2021, 10:54 PM   #7
Asshat
Asshat's Avatar
Where did you get that tank?
292, 4-speed
Old 06-26-2021, 11:32 PM   #8
AcampoDave
AcampoDave's Avatar
Maybe you just need a new sender. https://www.tanksinc.com/index.cfm/p...rod/prd831.htm
AcampoDave is offline   Reply With Quote
Old 06-27-2021, 07:57 AM   #9
MT65
I took measurements, made a pattern of the side panel, made the mounts for the sender and fuel pump, took these items to my local sheet metal shop and he made this “vessel “ for me, fuel tanks are forbidden due to %#=-+ lawyers……
Old 06-27-2021, 08:02 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
That was smart. I found the same negative response from machine shops. I'll remember this.
Old 06-27-2021, 09:19 AM   #11
sirJim
I did a newer suburban tank in my 62 burb with bands to hold it up works good dident have to remove anything to install. Might give you an idea.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 06-28-2021, 12:12 AM   #12
sirJim
Just looked it was a 73-81 Blazer tank 25 gallon I moved the filler to the side because I wanted the straps to go from side to side because of the cross suport.
Old 06-28-2021, 08:41 AM   #13
vince1
I put one in from a Jeep CJ hanging on some bed frame angle iron to the truck frame rails and got a fill setup from a Dodge P/U mounted just inside the box. It fills nicely. So far my problem is that I still need to get a sending unit to match the truck gauge. Currently I top it up about every 100 miles.
vince1 is offline   Reply With Quote
Old 06-28-2021, 09:09 AM   #14
jmarkha1
A mid 60s mustang tank slides between the rails nicely - to make it removable you would need to make the rear crossmember bolt in (which is what I had done) and I think this would allow you to fit and service the tank without removing the box. You may need to lift the rear of the box though to clear the main box cross member. I can send pics later this week if you are interested.
jmarkha1 is offline   Reply With Quote
Old 06-28-2021, 09:59 AM   #15
Chevy Fleetside
Chevy Fleetside's Avatar
And at www.tanksinc.com you can get the mustang style tank with a 0-30 ohm sender. . https://www.tanksinc.com/index.cfm/p...rod/prd502.htm oh boy a 22 gal option.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-28-2021, 10:01 AM   #16
jmarkha1
yes - its quite small - 16 gals.
i fitted a 7 inch tube style sender that is 0-30 ohm so connects with the stock gauge nicely.
Originally Posted by Chevy Fleetside View Post
And at www.tanksinc.com you can get the mustang style tank with a 0-30 ohm sender. The tanks are small though. I believe they are only 15 gallons and of course any aftermarket sender might not read right.
Old 06-28-2021, 10:48 AM   #17
sirJim
You know that using the original gauge and a new sending unit it only needs a resistor to make it work. couple threads on here as a how to.
http://67-72chevytrucks.com/vboard/s...d.php?t=210638
Old 06-28-2021, 11:41 AM   #18
Asshat
Asshat's Avatar
Yes, I read through those posts and tried the resistor upgrade. Still doesn’t work. I will have to remove the sending unit and check it outside of the tank.
292, 4-speed
Old 06-28-2021, 11:42 AM   #19
Asshat
Asshat's Avatar
Yes, please do post some pics. Thanks!
292, 4-speed
Old 06-29-2021, 02:15 PM   #20
pdxhall
pdxhall's Avatar
Here's my early Mustang tank It's only about 16 gal., though. but it fits nicely between the frame rails. When I ordered my gauges I just got one to match the Mustang sender.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-29-2021, 03:17 PM   #21
jmarkha1
exactly the same as my setup - apart from I mounted to the lower frame - the mustang tanks fit up nicely and bolt to the rails along the perimeter.
Old 06-29-2021, 07:53 PM   #22
AcampoDave
AcampoDave's Avatar
Originally Posted by AcampoDave View Post
This sender I linked needs no resistor to work with a stock guage. I use one myself and it does need to be set up to read properly, but it's easy to do. Measure the depth of the tank where it mounts, adjust the length of the sender and float arm as per the table in the directions and that's it....mount it up. EDIT: Oops...disregard everything I just said because it lacks a fuel pick up tube.....damn, mine is on an after market tank. This tank.... https://www.tanksinc.com/index.cfm/p...rod/prd173.htm
Old 07-05-2021, 06:09 AM   #23
Paul Y
I used the Jeep tank, I do have my bed off but as there is no trimming needed of the rails this 'should' be an easy fit with the bed on.
It is a side fill as well which should make things easier - only downside is capacity but that is not really a problem for me.
Have pictures on my thread or can send them to you if you let me know your details.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 07-05-2021, 09:59 AM   #24
vince1
I think I may lower the Jeep tank and cut a hole for a sender so that I can get it back to the 0-30 ohm gauge.
