Old 12-21-2021, 09:58 PM   #1
Afirehawk1
Boyds Welding Fuel Tank
I have this tank installed on my 66.
I am confused on the the 1/2 inch NPT vent. This is the rollover vent I think.
The other port 5/8 inch is for a vacuum canister.
I am installing a remote fill on the bed fender. See photo what i was planning. So should my remote fill have a port added then run a hose from that to the 1/2 inch brass fitting??
Regarding the 5/8 port; i dont plan on running a vacuum canister unless i have to; so just plug that port??
Afirehawk1 is offline   Reply With Quote
Old 12-21-2021, 10:05 PM   #2
MT65
Re: Boyds Welding Fuel Tank
The brass fitting sticking up is a roll over valve, it can be used as a vent easily, in the event of a roll over, it closes and doesn’t let fuel out. The other port…? You may want to call the manufacturer and question them….
MT65 is offline   Reply With Quote
Old 12-22-2021, 09:57 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Typically, you want to vent the tank at the highest point, including the filler neck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-22-2021, 10:27 AM   #4
Afirehawk1
So would i connect the brass fitting on the tank to the small port on the filler neck that i have shown above?
Old 12-22-2021, 10:38 AM   #5
MT65
That would work fine…
Old 12-22-2021, 10:49 AM   #6
Afirehawk1
Thanks for the help!
Old 12-22-2021, 04:33 PM   #7
forestb
forestb's Avatar
That doesn't sound right. Unless I misunderstood what was being said.
If you do that wouldn't you just be recirculating the fumes instead of venting it. I think you need to plug both holes on the top of the tank and run the vent from the bung in the filler neck into the open air through a hose. Make sure the vent hose has a couple of loops in it which will keep the smell of gas from escaping.
forestb is offline   Reply With Quote
Old 12-22-2021, 04:35 PM   #8
seabeevin
seabeevin's Avatar
Don't you connect a vent hose from the filler neck to the tank?
65 stepside C20
seabeevin is offline   Reply With Quote
Old 12-22-2021, 04:41 PM   #9
Afirehawk1
I have attached another version of the side fill tank with a secondary smaller tube next to the 2 inch. Mine is like this one without the smaller tube
I know the brass port is a rollover vent but should go to something
Second figure is from boyds website
Regarding the vent line connection
Thus why im confused
Old 12-22-2021, 04:46 PM   #10
forestb
forestb's Avatar
I am not seeing any links. never mind now I do. but it is too blurry to read.
Old 12-22-2021, 04:49 PM   #11
seabeevin
seabeevin's Avatar
The pictures look identical
65 stepside C20
Old 12-22-2021, 04:49 PM   #12
Afirehawk1
Had trouble loading
Old 12-22-2021, 04:52 PM   #13
forestb
forestb's Avatar
Now I understand the confusion. I would call Boyds.
Old 12-22-2021, 04:53 PM   #14
Afirehawk1
Other photo
Old 12-22-2021, 04:57 PM   #15
Afirehawk1
I think the idea is when i fuel the tank remotely, as the fuel is placed into the tank, the vapors have to be pushed out and is circulated. i was going to use a vented fill cap as well
Old 12-22-2021, 05:31 PM   #16
forestb
forestb's Avatar
It might also be that if it is that low on the side there might be a tendency for the gas to slosh back up the filler neck and this would provide a place for it to go rather than out the cap which could ruin your paint.
Old 01-05-2022, 01:16 PM   #17
Afirehawk1
on the rollover vent. there is mention of the old style vacuum carbon canister.
any suggestions or ideas on that?
im using this filler cap instead. its a 1.5 inch filler pipe with an an overall of 2.5 inches. this fits perfectly on the top of the rear bed fender.
