#301 |
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
Looking great Scott! You are making a ton of progress. Are you going to run the wire bundle up on top the firewall like the factory? I am thinking about doing that, but I don't like how the ignition wire comes down the center of the firewall to get to the distributor if that makes sense.
Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
#302 | |
![]() Join Date: Oct 2012
I went a little crazy on zip ties, but they make everything look clean and organized. I still want to wrap the wires showing coming out of the fuse block a little better at some point as well.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#303 |
That looks clean Scott! I may try that rather than go over the top of the firewall. What did you use to seal up the edges of the fuseblock? Is that seam sealer?
Clay
#304 |
![]() Join Date: Jun 2002
Nice work on the wiring in the engine bay. It looks really clean.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#305 | |
https://www.eastwood.com/ew-flexible...-bk-2-lbs.html Thank you! I'm pretty happy with how it turned out.
#306 |
![]() Join Date: Oct 2017
Indeed, that firewall/engine bay looks VERY clean
![]() Looks like Eastwood is relabelling "3M Strip Caulk", ...great stuff for sure ![]()
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
#307 |
Just a few things got wrapped up this weekend. I dropped the starter and got the power and solenoid wired, finished routing the rear light wires to the back cross member, and I finally got the parking brake installed.
I had to modify the cable on the parking brake a little bit as I tucked the exhaust up and that interfered with the stock routing. I ended up making a new passenger side bracket from some 1" flat stock and welded a threaded rod on the end to replace the long rod that way hitting the exhaust. Or course I couldn't find the clamp that holds cable to the parking brake assembly, so I had to order a new one. I'm sure I'll find mine after it gets here. I had found the bolt for it, but the clamp wasn't with it. I'm sure I put it somewhere safe ![]() Hopefully some lighting parts will show up this week so I can get the grille bolted on the front and see some bright lights and blinking
#308 |
Thanks! Ya it's pretty much the same as the 3M stuff.
#309 |
![]() ![]() Join Date: Jan 2005
Great progress. Hooking up the battery will be a big milestone, and it looks like you're getting close.
#310 |
Just got the front windshield and rear glass installed. They look great! I paid an auto glass company to do the job. It was cheaper for them to install and provided the glass and rubber seals than it was for me to buy the glass and rubber alone, so it made sense to pull the trigger and have some pros do it. 2 dudes showed and it took no more than 20 mins to do both front and rear installs.
Lights and bezels get here tomorrow ![]()
#311 |
Getting there piece by piece!
#312 |
I am going to call the same guys for mine! Thanks for the referral Scott!
Clay
#313 |
You bet man!
#314 |
Progress weekend! Baby stepping to the finish line.
I got all my front lights installed and the wiring harness connectors crimped and plugged in yesterday.... and they actually all work! Low/High beam, parking lights, fender lights, turn signals. Pretty satisfying to turn them on. Got the dash pad bolted on so the whole dash is starting to come to life. Tested the lights on the gauges and they're good as well. I installed some door switches for the courtesy lights. I think I need to check the ground on them as they stay on even when the switch is pressed (maybe need to scrap some paint off where they thread into the jamb?). Also tossed on the dome light but still need to splice that connection into the courtesy light wiring on the drivers side. The AAW kit is fantastic, all the connectors are super easy to crimp (with the correct tool) and slide into the end connections for a super clean finish. The wiring project has been very enjoyable to me, almost therapeutic. It was great to start with a clean canvas for the install. The inner grille shipped with all my lights/bezels so I got to work bolting it to the outer piece. I saw in IronCanine's build thread a post talking about the (7) sections on the inner grille https://67-72chevytrucks.com/vboard/...&postcount=362 being black so I grabbed a black paint marker and colored mine to match. I think it looks great with the black separating the silver sections.
#315 |
Couple pics of the completed front minus a bumper.
Next up will be getting the doors/windows finished up. I have some new regulators from AMD and new glass/weather stripping coming from Precision coming this week. I still need to buy some new vents as mine old ones are trashed and broken.
#316 |
Man, she is looking great Scott!! I am still waiting on my crimper to ship....once it does I can start on my harness as well. Great job man!
Clay
#317 |
![]() Join Date: Mar 2011
great progress.... the grill is outstanding....has really a nice touch to it .. Im going to be a copy cat hope you don't mind.... I bought some of the chrome paint to see if I can do the outside edges of the grate ....will be a long time till I get to that your build and progress is captivating to say the least
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#318 | ||
#319 |
chevy truck fan
Scott, I agree with you as well. The forum is a huge wealth of knowledge and agree with the shout outs too. I also agree with the others ..... GREAT PROGRESS!!
#320 |
Looking great!
-------------- 1970 C/10 LWB build thread: https://67-72chevytrucks.com/vboard/...d.php?t=847860 IG- Tip70 https://www.etsy.com/shop/Tip70Designs |
#321 |
I'm still waiting on a couple window/door parts to all get here so hopefully I can tackle that install this weekend. I needed to clean up the sash channel, they're just a little dirty and have some surface rust. I capped off a 2" PVC pipe and filled it with some Evapo-Rust. Way easier than busting out the sandblaster. Just need to clean the larger end and get some paint on them.
I managed to score a steering wheel yesterday. I'd been checking Offerup and Clist for a while for an 88-92 OBS wheel since IMHO, they're the best ![]()
#322 |
I'm with you Scott....the OBS steering wheel looks great in these trucks! Also, a great idea on using the 2" PVC pipe to dip the window channels into...I am gonna have to try that when I do mine.
Clay
#323 |
chevy truck fan
WOW!! that evapo rust works really well!! I have never used it, now I know to get some!.... the OBS wheel always look good no matter what they sit in... nice thought. oohh by the way.... what is in that little glass at the upper right of the last picture?......
#324 | |
The glass was just a little night cap of some Woodford Reserve. ![]()
#325 |
That's very impressive rust removal. I've heard that the Evaporust they sell in CA isn't as effective as the stuff that's available other places. I might need to smuggle some in the next time I'm in AZ.
