Push Button Lock
1968 K10 Suburban all original.
What are you guys doing when your push button lock (rear tail gate clam shell) breaks? I have the original key and now it won’t unlock. I would use the the push button lock often so I know it worked. I have been to 3 local Locksmiths and I get no where. They always send me somewhere else. “I don’t have the tools to take it apart.” “That’s too old for me” “we tried 250 keys. We are not authorized to open the lock”. Looking for help. Posted via Mobile Device |
#2 | |
The Older Generation
Re: Push Button Lock
Will the key still slide into it? There is a cover over the tumblers on the inside. It can come loose and pop up. If that happens the key will still slide in but the lock will not turn. If you want to send it to me I will take a look at it and see what I can do. I have fixed quite a few of them. I will PM you. LockDoc
"We are not authorized to open the lock..."
WHAT???
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
#4 | |
![]() ![]() Join Date: Mar 2016
LockDoc did a great job for me on my 68 Burb. I would recommend him any day.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE ![]() |
Leon is the man! He overhauled mine and now it's butter smooth.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#7 | |
Thanks guys. I think his lock is on the way.... ![]() LockDoc
Lock is fixed. Just as I thought, the cover came loose and popped up. You can see it in this picture. It is supposed to be down flush with the lock surface. I removed the cover and twisted the "tabs" on each end of the cover so it would stay in place long enough for me to re-stake it. You shouldn't have any more problems with it.... This can also happen to door and ignition lock cylinders. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-26-2023 at 06:27 AM. Reason: Added Info |
#9 | |
Knuckle Buster, Instructor
![]() Join Date: May 2010
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 72 GMC Suburban 1500 Super Custom. White/Med Olive/White, Parchment interior. 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue 78 AM General M35A2C with winch, multifuel with C turbo, bobbed deuce on 47” tires. |
#10 | |
That would be doable as long as the replacement keys will slide into the original lock easily. .
My replacements haven’t arrived yet. Once they do, I’ll see if they are compatible. If not, can you disassemble the push button and determine the code for a replacement key? I’d like to have it working even if it takes a separate key.
#12 | |
Take a look at this thread I posted back in 2013. I shows how to find the code number on the tailgate lock, if it has one. http://67-72chevytrucks.com/vboard/s...d.php?t=561226 If it has a code number I can cut a key from that, or you may have a locksmith local to you that can cut the key from the code number..... Let me know what you find.
#13 | |
#14 | |
I purchased the hand key punch and code books when a local Chevy dealer went out of business a few years ago. I have used it a lot. Let me know if you need anything. .
| Bookmarks |
