#32 |
![]() ![]() ![]() Join Date: Jan 2018
Re: Frankentruck
It’s easy to get an aftermarket 63 switch and components, but if your switch body is still good, you may just need the cancelling cam. I would check wiring before condemning the switch as bad.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
| Bookmarks |
