Old 02-04-2026, 09:32 PM   #1
GeoffK
Gas leak?
Took the 72 out for a spin, got groceries and filled it up.
Stopped for like 5 minutes (not running) to get matching vintage cooler and there was a gas puddle on the passenger side by rear wheel. The truck was parked at an angle ( passenger side slightly lower).
I came home and it isn’t leaking now? Any suggestions?
GeoffK is offline   Reply With Quote
Old 02-04-2026, 11:50 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gas leak?
That's a strange one. Possibly leaking around the sending unit hole or the return line on the tank? Was there a strong smell of gas in the cab?
Leon
Old 02-05-2026, 12:13 AM   #3
GeoffK
Re: Gas leak?
Originally Posted by LockDoc View Post
That's a wired one. Possibly leaking around the sending unit hole or the return line on the tank? Was there a strong smell of gas in the cab?
It hasn’t replicated and I’ve checked every 15 minutes or so. I actually put it back in the garage.
No smell of gas in the cab at all, can smell it outside a little where it leaked but I don’t see anything.
Old 02-05-2026, 03:53 AM   #4
Richard
Re: Gas leak?
Filler neck connector hose original? 50+ years takes its toll. You mentioned a fill up. Could have leaked onto top of tank and dripped to passenger side. Still running a sealed (not vented) cap?
Richard
Old 02-05-2026, 02:25 PM   #5
GeoffK
Re: Gas leak?
I have to crawl under and take a look. Yes running a regular non vented cap.
Old 02-05-2026, 06:55 PM   #6
HO455
HO455's Avatar
Re: Gas leak?
On my 67 Burban there is a hidden piece of fuel hose on the passenger side near the 3rd door pillar in front of the trailing arm crossmember. It is a 5-6" U-shaped hose that connects the steel in from the fuel pump to the steel line that goes to the fuel tank. I don't know if it is that way on all 67-72 Burbans of only 67's.
I cut the 90 degree bends off and replaced mine with compression fittings and a piece of steel line. Circled in photo.
RIP Bob Parks.
Old 02-07-2026, 05:25 PM   #7
3drburb
Re: Gas leak?
This would be my guess also. My 72 U hose was cracked and leaking also.
If you find another leak, it may be good to clean this hose and check it for cracks or just replace it anyways.
Good Luck.
3drburb is offline   Reply With Quote
