04-04-2010, 11:54 PM | #26 |
Re: my daily driven '68 LWB 5.3/4l60e
What a great truck!
What motor mounts did you use? |
04-04-2010, 11:57 PM | #27 |
04-05-2010, 12:02 AM | #28 |
Moderator
Nice truck. I ran one of those seats for years, they make them completely different trucks and comfortable to drive.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
04-05-2010, 12:03 AM | #29 |
Had to post my favorite picture of the '68......none of the modern junk in the background of this one.
04-05-2010, 12:06 AM | #30 |
Sweet picture! What gear do you have in the rear? What kind of mileage are you getting?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-05-2010 at 12:06 AM. |
04-05-2010, 12:17 AM | #31 |
Well, I ran 3.73 gears up until 3 weeks ago. Now I've got a '70 rear end with 3.08s. Something in between would be perfect. I get 16 mpg driving 65 mph and under and drops like a rock after 70. Ive never gotten less than 13 mpg. The 3.08 gears are just too high to drive on the interstate at 70 mph unless its a fairly flat grade. I really liked my 3.73s better, but the '70 rear end was the right width to match the front disc brakes and easily keep everything 6 lug (I have 6 lug rotors up front).
04-08-2010, 11:34 AM | #32 |
I am wondering how and what you used to put a connection in the bottom of the gas tank,and does it leak? I'm thinking of doing this swap and would like to keep the stock tank as well. By the way I cant see your pics any more.
maybe something wrong on my end though. |
04-11-2010, 12:45 AM | #33 |
I used a bulkhead fitting and o-rings. Very similar to this one.....
Be sure to drill a nice clean hole and use the proper o-rings. I had trouble out of mine after a year because the o-rings I used were not supposed to be used with fuel. After using the right o-rings I've had no problems. Its been two years since I made the repair. If it happens again I'm going to epoxy the bulkhead fitting to the tank. I used the factory fuel supply line on the top of the tank as a return line. Last edited by speed-racer; 04-11-2010 at 12:49 AM. |
04-11-2010, 04:24 AM | #34 |
I like your style!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
04-11-2010, 11:05 AM | #35 |
Your truck is sweet, I'm digging your style as well. Since you did this swap, changing a gear set should be no problem for you. Other than that, I wouldn't change a thing on your truck. I like the stance, wheels and everything. Though I'm partial to the stock style black vinyl seats. My K20 isn't much more optioned than yours. I for one prefer it that way.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
04-11-2010, 11:45 AM | #36 | |
04-11-2010, 11:53 AM | #37 |
The seat in my 67 is from a 72 Cheyenne Super, and it is really springy, which helps with the rough ride. My 72 has a seat out of an early 90s 1500 w/t, and it works out pretty well. I dig what you're saying though.
