05-04-2014, 09:14 AM | #26 |
Re: Anyone else tried to order truck rallies from Wheel Vintiques lately?
bummer, i bought a set too... i'll check the welding and post a follow up...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
05-04-2014, 09:34 AM | #27 |
Can you order them bare (not painted) and then either have them powder coated or painted yourself?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
05-04-2014, 06:33 PM | #28 |
looks like the truck rally will be coming back but with a 4.5bs not the old 5" style. part number on summit has changed.. may.9th is when they should be in stock. I have been waiting a long time for these. So don't buy my set!! LOL
http://www.summitracing.com/dom/part...5042/overview/
1987 GMC Wrangler 350/700r |
05-04-2014, 06:35 PM | #29 |
checked mine, WVI-37-580504 the welds are all ok, so i guess i got a good set...
05-05-2014, 06:38 AM | #30 |
emailed Summit regarding the WVI-37-580504 wheels.. here is the response
Those wheels were not involved in the recall. We inspected all of the inventory when we were notified of the recall and notified anyone who purchased wheels that may have been affected. Thank you for your inquiry, Summit Racing Equipment
05-05-2014, 06:46 AM | #31 |
I know the pieces fit
When I bought mine they showed up grey with a sticker on them that said they had a primer finish and needed a to be painted. Not what I expected since the product description said they were painted silver. I had them powder coated.
05-05-2014, 07:55 AM | #32 |
Robert Olson Transport
the ones I bought were suppoused to be properly finished evidently it was a hack job.. Earl scheib coulda painted em better
09-06-2014, 12:24 AM | #33 |
What is the proper 15x10 backspacing for a 1972 C10 lowered?
09-06-2014, 04:29 PM | #34 |
That is a subjective question. I'll tell you 5"bs sets the wheel in the center of the well when using a 71-87 length housing. Change the housing to something different & the back-space needs changing.
Another guy will come along shortly & tell you he has 10's w/3.5" of back space & they work fine. It depends on how the rest of the truck is set up to give the best suggestions in my opinion.
09-07-2014, 09:14 PM | #35 |
Mine just in came in.
04-07-2017, 04:19 PM | #36 |
ive been eyeing these 37 series wheels, but wasnt sure if they would work with my disc brake setup (1972 C10 chassis), seeing your pics makes me assume they do? I have disc front and rear and was wondering if they were disc brake compatible. (i need 14" to clear the rotor/caliper on both the front and rear)
Summit and WV stated these were for pre 71 trucks and would not work. |
04-07-2017, 04:52 PM | #37 | |
04-07-2017, 04:56 PM | #38 |
when i spoke to summit tech line, they specifically stated "oops we have this mislabeled they are actually for prior to 71 trucks without disc brakes" and no one at wheel vintiques can give me a definite answer if they will clear the calipers
04-07-2017, 06:18 PM | #39 | |
I would put money they're using the latest in rim hoops & would imagine they're doing the same as far as the centers are concerned. I've seen more than 1 disc brake equipped Chevy 4x4 w/WV 'car ralleys' which follows my trend of thought since disc brake spec'd wheels will also fit drum brake equipped trucks. It does not make sense to utilize pre-71 6x5.5 drum brake center dimensions when disc brakes are so common (thus limiting the application variety). If you build wheels using disc spec'd centers, you only need to stock 1 type of center vs 2 (disc 6-lug center & non-disc 6-lug center).
