Old 05-08-2015, 09:33 AM   #26
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Do you have a 4WD with a 3 SPD on the colum transmission?
You'll need to keep the pivot point in the original position for the lever to go flat parallel to the floor as well as to clear the seat in the vertical position.
I'll use the top of my frame as a reference point off of my setup and the distance from the TC to guide your installation/modification.
What is the casting code on the 3SPD?
Old 05-08-2015, 09:43 AM   #27
pimpston65
pimpston65's Avatar
i can make mods, while keeping the original location, can't be jacking up my TC
pimpston65 is offline   Reply With Quote
Old 05-08-2015, 11:04 AM   #28
60-66
60-66's Avatar
Heres a picture of the three speed controls. Our 66 K10 Panel is a three on the tree 4x4 . Ill get you some pictures later from that.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-08-2015, 11:13 AM   #29
aerotruk63
aerotruk63's Avatar
Your the best 60-66!
Never thought to look in that book.
Old 05-08-2015, 12:37 PM   #30
pimpston65
pimpston65's Avatar
what the hell, i have that book!!! Once again we bow at your feet Jon...
Old 05-08-2015, 12:42 PM   #31
61K10
61K10's Avatar
I thank he has one of every combo built lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-08-2015, 01:12 PM   #32
60-66
60-66's Avatar
Here you go Winston, or as the say in Canada "LePimp" . The bracket is cast . Looks simple enough to make. This truck has the short 3 speed trans. The high hump is needed only to clear this tall shifter bracket for the transfer case,
Old 05-08-2015, 01:29 PM   #33
aerotruk63
aerotruk63's Avatar
Thank You 60-66!
Group 4.563 BRACKET, TRANSFER CASE CONTROL LEVER
2408040 1961-62/ ALL 4WD W/4 SPD TRANS PIVOT BRKT
3823426 63-66/ ALL 4WD W3 SPD TRANS ( no listing for the bracket in the 58-64 parts book, weird )
3823427 63-64/ ALL 4WD W/4 SPD TRANS ( listed in 58-64 and 65-75 parts book though N.L.A. in 1975)
Old 05-08-2015, 01:33 PM   #34
pimpston65
pimpston65's Avatar
so now i gotta find someone selling it, im just gonna mock up one over the weekend. finding that thing would get insane...
To the wtb section here i come!!! THANk YOu ALL!!!!!
Old 05-08-2015, 02:04 PM   #35
1963c-10
1963c-10's Avatar
Too bad they aren't closer to the 2 gen k series. The 67-72 guys say the 3 speed 4wd was pretty common on their trucks. I found documentation on the 1st gen's with them, but no pics..... but like the rest above....I didn't check the assembly book either.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-08-2015, 02:08 PM   #36
pimpston65
pimpston65's Avatar
darn and i was to leave the burb alone this month, well i do need to either make or find the part!!! i can spare a few hours searching the WWW for it... the best is i know what the part looks like...
Old 05-08-2015, 02:11 PM   #37
60-66
60-66's Avatar
The three speed in the K 10 and K 20 series was standard equipment according to the Data books , the 4 speed was optional . Should be more out there but I would have to say less common .
Old 05-08-2015, 02:21 PM   #38
aerotruk63
aerotruk63's Avatar
I've been searching by part number and so far nothing. I did however find original shackles and pins for jonzcustomshops C30
Old 05-08-2015, 11:16 PM   #39
bhc41051
bhc41051's Avatar
would be very easy to convert to a 4-speed, since you already have the high hump with the 4-speed hole. The guy I PM'd you about had a high hump with just the transfer shift hole but that was a while back. He has the hard stuff but be prepared to pay a premium price.
bhc41051 is offline   Reply With Quote
Old 05-08-2015, 11:48 PM   #40
pimpston65
pimpston65's Avatar
the PO had a 4speed in it, but since i wanted to build it as it left the factory, i switched it to the 3speed. thks for the info i called him and just waiting on pics and other info!!!
Old 05-09-2015, 12:04 AM   #41
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
been looking at this thread... too cool to do a column shift 3 spd w/ 4wd
wish I could help, but all the 4x4 stuff at the local wrecking yard is picked clean of everything 4x4 but the vin tag!!
Old 05-09-2015, 12:06 AM   #42
pimpston65
pimpston65's Avatar
thanks for checkin in, i found the correct bracket and spoke with the guy. once its in my hand and mounted i will post pics!!!
Old 05-09-2015, 09:55 AM   #43
aerotruk63
aerotruk63's Avatar
Talked to the PO of LeBurb this morning. PM'd you the translated details.
Old 05-09-2015, 11:56 AM   #44
pimpston65
pimpston65's Avatar
maybe they can give old pics, back in the day when it was a working burb???
Old 05-09-2015, 12:24 PM   #45
aerotruk63
aerotruk63's Avatar
Oh that would be cool to see! I`ll have to bring a scanner to make copies of the pictures.
Amazing how quickly your able to find parts. Well thanks to the board members!
What`s next?
Old 05-09-2015, 12:53 PM   #46
pimpston65
pimpston65's Avatar
What`s next?
i will make real copies of LeBurb this week. well I'm calling off work today!!! i have 3 days off so ima rock some bodywork OUT... block,block block,repeat!!!
