10-01-2019, 04:38 PM | #26 |
Re: Wheel Spacers - Good thing?
I'm still planning on getting you some pictures, but been raining here non-stop so I haven't had the truck out. FWIW, the adapters in the rear makes a huge difference in looks. Before, I would be told that my truck was crab walking on multiple occasions, and then I would have to explain that the front track on Blazers is 4 inches wider than the rear which gave it that illusion. There's zero effect on how the truck drives with the adapters installed.
10-01-2019, 06:12 PM | #27 |
Nice that’s what I’m looking for.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
10-04-2019, 03:42 PM | #28 |
Finally stopped raining !! Here's my truck with 1 1/4" spacers on the rear.
10-04-2019, 03:49 PM | #29 |
Carpe manana
So with spacers you get increased deposition of road debris and grime along the body? How are these an improvement?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
10-04-2019, 04:16 PM | #30 |
It's an improvement because these trucks look like crap going down the road with the front track being 4 inches wider. Road debris and grime is more of a problem with the front wheels anyway. Debris on the rear is a mute point.
10-04-2019, 05:55 PM | #31 |
Carpe manana
Yeah, makes perfect sense now
10-07-2019, 11:22 AM | #32 |
I hate mud so it will never see it. I don’t even drive it in the rain. It’s a summer toy for me. It does look good with the wheel spaced out.
10-07-2019, 10:01 PM | #33 |
x2
-Bruce 1971 K5 Blazer 4WD |
10-10-2019, 04:16 PM | #34 |
I thought the front was 2" wider, but I've seen 3" and 4" on this thread. Which is it?
'72 K5, known as 'the Fox.' |
10-10-2019, 10:14 PM | #35 |
Agree wheel spacers are not a good product to use. If using spacers only use high quality forged alu. Do not use cast Alu or cheap forged. Also when using spacers you need to regularly check wheel nut torque. Under high loads they will loosen. This is from experience using spacers. I was taught the above by professional racing engineers.
Les |
10-10-2019, 11:50 PM | #36 |
10-11-2019, 12:18 PM | #37 |
Swapped a 14 bolt in the rear and converted front to 8 lug. Looks even to me
10-11-2019, 07:02 PM | #38 |
It's amazing how much it improves the look, and no more people telling me my truck is crab walking. The only hassle was to have to remove the wheels after 100 miles to re-torque the adapter, but well worth it. Got over 1000 miles on it now.
10-13-2019, 07:17 PM | #39 |
Please allow me to ask a dumb question that somewhat pertains to this subject. My drivers side front wheel sticks out 1" further than the front passenger side. There's no spacers or adapters and the wheel appears to be the same width. Is my just screwed or is this because of the steering components on the driver's side?
72' JIMMY 454 |
10-14-2019, 12:09 PM | #40 | |
Perhaps you can add some more pics to that thread and we can try to figure out what's going on? |
10-14-2019, 12:53 PM | #41 |
Will do! I'll put them on the other thread this evening, hopefully. Thanks
72' JIMMY 454 |
10-14-2019, 05:17 PM | #42 |
Measure the distance from the inside of the front tire to the side of the frame. If the measurements are the same, then this will rule out the axle being shifted to one side. I would then look at the front sheet metal being off location. (rotted/broken body mounts or rad support.)
11-06-2019, 09:22 PM | #43 |
I'm getting used to asking dumb questions on here. so.... how do 1.25" spacer/adapters make up for a 3"-4" difference? I don't want to order them and they still not match the front.
I assume this is what I want? 2 Chevy Truck 6x5.5 Wheel Spacers 7/16 Thread | For 1967-1991 1/2 Ton Trucks Thanks
72' JIMMY 454 |
11-07-2019, 08:54 AM | #44 |
I think they were talking per side?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-07-2019, 08:59 AM | #45 |
I figured that. 1.25" x 2 doesn't equal 4" I should have asked more clearly.
72' JIMMY 454 |
11-08-2019, 01:43 AM | #46 |
It’s probably to just get it more in line and not use too thick of a spacer.
11-08-2019, 09:23 AM | #47 |
Thanks, I ordered 1.5" from wheeladaptersusa. If they are too thick I will give them to my wife for Christmas to use as a trivet, then order some 1.25" ones.
72' JIMMY 454 |
11-13-2019, 09:41 PM | #48 |
72' JIMMY 454 |
11-15-2019, 02:29 AM | #49 |
Nice. Get some before and after shots!
11-19-2019, 02:14 AM | #50 |
What size are the studs on the adapters? I’m thinking of putting in 1/2” studs on the rear.
