Active Member
Hard top rear mount.
Just curious if all our Blazers got the mounts pictured below? Were they for a single wall top? My dad's Blazer has these mounts, but mine does not. Mine does not even have a hole where they might have been mounted. Also what would be the advantage of adding these mounts compared to without?
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
The LuvShack Garage
Re: Hard top rear mount.
I just got outbid on those, where you the lucky winner?
![]() Every top I have ever owned on all 4 of the Blazers I have owned has had them, oh yea and I had 2 of each type top.
Owner/Op: "TN Classic Transport Carriers" Daily Driver: "HerNameIsRio" 68 GMC SWB The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Toy Hauler: "Feathers" 14 Aluma 8218T |
Definitely would put those on. You have a 70 blazer I see. One thing I can tell you is I have a 70 and it does not now have the drip caps. No holes where they were. Just a big black rubber plug. So you might have a late 69/early 70. Alot of the time with a first year new model the changes that they make don't make it on to the 1st few of the following year. Call it a 70 and get it out.
Active Member
I was also outbid, was not sure if i really needed them. You were just above me on the bidding.
The LuvShack Garage
OIC, I had 2 sets already, I have 2 tops, and then was gonna sell one of my
sets, but I just couldn't go that high, I was already higher than my max was.
Owner/Op: "TN Classic Transport Carriers" Daily Driver: "HerNameIsRio" 68 GMC SWB The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Toy Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 12-10-2006 at 10:33 PM. |
Active Member
Here is a picture showing that there is no mount hole on the bed side for these mounts on my Blazer.
The LuvShack Garage
Yeppers, the hole is missing, but that's a easy fix
#8 | |
Active Member
The build date of mine was 10/69, so it would have been a very early 70. Mine is also a Jimmy and not a Blazer. I just don't care for the Jimmy front end, so i am going to put on a 69 Blazer front clip. Right now i am just collecting parts for it, until i have enough to tear it down and rebuild it.
![]() Join Date: Jan 2005
Mine is a '69 and also does not have the holes. I just bought a set from teeitup and will be cleaning them up and installing them soon. Not sure how I want to approach the hole drilling yet, I might weld in a piece of plate that can be threaded.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
No, not missing just not being used quite right.
Can't believe you missed that one LUV...
Future TOTM Winner
I think what everyone is saying is that the bolt hole is missing from the tub's sheetmetal, not the fiberglass top.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Just need a couple more parts.
What are the two pieces in in the pictures with the black square looking circle drawn around them? I think a set of those arrived with my blazer in a box of spare parts.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
#13 |
These are the rubber bumpers that cushion the hatch as you bring it into contact with the top. They mount on the upper bolt.
#14 |
Hard to see in this picture but it this one that the rubber has maybe worn off of?
#15 |
Blazerless
My '70 Jimmy didn't have those brackets. Everytime you hit a big bump, the hatch would pop open! Definately recommend installing them. My '72 has these brackets, and the hatch never pops open and doesn't rattle as much.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD 69' Beaumont 388/700R4 11.70@116 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
#16 |
#17 |
The LuvShack Garage
#18 |
Active Member
my single wall top has these brakets yet my hatch seems to be missing the hardware that actually latch onto them. All it has is the little tab that swings down onto the tailgate? I think its a crappy set up and hope to find the rest of the hardware someday....
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it )
#19 |
SKINNY TIRES RULE!
There isn't anything on the hatch for any of these brackets. Can you take a picture of what you are talking about.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#20 |
SKINNY TIRES RULE!
Not such an easy fix. The hole has a threaded insert to accept the bolt and there isn't any access from behind to put a nut on it. I guess you could use a speed nut or something, but I don't think just a hole will work (unless you are just going for the look).
#21 |
The LuvShack Garage
Why use a bolt? if you are making the hole from scratch why not inovate,
that's why I said it was a easy fix, of course I can't tell ya what I would do, top secret, but their are alot of one-way fasteners if ya look around.
#22 |
SKINNY TIRES RULE!
OIC. Just because I look dumb, doesn't mean I'm not!
#23 |
![]() Join Date: May 2006
LMAO, Sorry guys but I don't see the 'easy fix'
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#24 |
The LuvShack Garage
Never said you were, but now you have me rolling on the floor
#25 |
Active Member
I thought the hatch had bars that ran from the handle to the ends to latch onto the two silver hooks in the center of the pic up top. Sorry my truck is up at the shop, ill get a pic this weekend if you still want to see what i mean.
Does anyone elses hatch lock onto the tailgate itelf or do i have a morphadite garage door opener handle for a hatch.....? haha
| Bookmarks |
