Old 06-11-2007, 06:33 PM   #1
56chevy1300
56chevy1300's Avatar
Autometer electric guages
I am looking at an Autometer electric guage set for my 56. I want to use the stock fuel tank behind the seat. Does anyone know if the electric fuel sending unit will fit inside my stock tank without any mods? Thanks in advance.
56chevy1300 is offline   Reply With Quote
Old 06-11-2007, 06:55 PM   #2
56chevy1300
Re: Autometer electric guages
This is the set I'm looking at...Old Time Whyte.
Old 06-11-2007, 07:33 PM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
I think the sender is different and wont just drop in. Why not pick up a new one for the tank and get the correct gauge to work with the sender. My autometer set came with the universal one. I bought the proper GM gauge and sold the universal one with sender on ebay to recoup some money.
Brian ..
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-11-2007, 07:49 PM   #4
texascowboy593
texascowboy593's Avatar
If your buying the set specifically set up for your truck...It'll be right. I bought the 5 gauge set from Brothers (Autometer) and it was correct. As long as the fuel gauge is a 0-30ohm unit you wont have any problems.
I had put in a 80's Blazer tank in mine and I had to change out the fuel gauge from a 0-30 ohm to a 0-90 ohm unit. Hope this helps!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 06-12-2007, 04:36 PM   #5
56chevy1300
I checked with a local distributor and they told me that the fuel sender is 240-33 ohms...does this sound correct?
Old 06-13-2007, 06:12 PM   #6
texascowboy593
That could be right...If your using the original tank. I'd call Brothers www.brotherstrucks.com and tell them what you have. I believe the 55-59 trucks all had 0-30 ohm original senders but I could be wrong!
1977 Silverado K10
Old 06-18-2007, 12:56 AM   #7
MrSinister
MrSinister's Avatar
You can get the gauges thru summit or jegs for the stock 0-30ohm sender,the 240-33 is for f!@d. That's what I did.
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 06-18-2007, 02:50 AM   #8
Ed ke6bnl
If you can get to the sender float you can take an ohm meter to it and test the ohms then you will know for sure. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
