Old 06-23-2008, 12:27 AM   #1
Green Machine
Green Machine's Avatar
Disk brake shields question ?
Doing the front disk brakes on our 1971 C20, one of the tin shields is kind of mangled, are these really needed on there, can we safely run without or is there a downside ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-23-2008, 07:08 AM   #2
70GMCer
70GMCer's Avatar
Re: Disk brake shields question ?
Not using mine.....no problems.....also 70c10 not using either......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-23-2008, 07:26 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Steve, remember I am using them Too much SunDrop affecting your memory
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-30-2008, 05:55 PM   #4
70GMCer
70GMCer's Avatar
Damn!! I've got "CRS"
1997 GMC Sierra Ext
1965 Mustang
Old 06-30-2008, 06:02 PM   #5
d10s69c10
Built 4 Speed
d10s69c10's Avatar
theres no real downside aside from maybe more brake dust going into you engine compartment.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 06-30-2008, 06:20 PM   #6
cdowns
cdowns's Avatar
too bad you dont have a block of wood and a hammer you could straighten them out
Old 06-30-2008, 06:34 PM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
Ya those damn rare blocks of wood!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 06-30-2008, 06:42 PM   #8
Shane
Shane's Avatar
they are there more for cooling purposes than anything else ...
Shane is offline   Reply With Quote
Old 06-30-2008, 09:45 PM   #9
Green Machine
Hey, I might be lazy, but I'm not that lazy ! Actually have a parts truck with 2 good ones on there but then I have drive 5 miles to get to it, then crawl thru the weeds, and jack it up. Then remove 8 rusty lugnuts, and some stuck caliper bolts, then I get to play with some greasy old wheel bearings just to get to it. I'm just not motivated to do that right now
Old 07-01-2008, 12:35 AM   #10
MisterE72
Keep Your Nose Clean
Just a little something I learned when I was shopping around for a replacement for my truck: The aftermarket shields usually have a beveled outer edge, while the originals have a sharp edge as you can see in the pics. The aftermarkerts below are from Early Classic. They run about $22 each. Mine was not that banged up, so I chose to go with the the hammer and block method. Just my .02 cents. MisterE
MisterE72 is offline   Reply With Quote
Old 07-01-2008, 03:41 PM   #11
lts70
1970 Daily Driver
lts70's Avatar
Don't make this in to a RARE topic. I don't see how blocks of wood are rare, I can get them in aftermarket from many suppliers in my area. Now hammers those are hard to find and removable and reusable too.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 07-01-2008, 04:06 PM   #12
Riveted1
Tasty Cakes!
Riveted1's Avatar
I have a rare corvette optioned hammer if you wanna buy it
And I apologize to Green Machine. You were asking a legitimate question, sometimes my (and others apparently ) love of sarcasm gets in the way! As others have said, while the shields are not absolutely necessary, they do serve a purpose.
