Old 07-04-2008, 03:33 PM   #1
93Sierra
93Sierra's Avatar
Help with single headlight grille to composite
Hey guys. I've been looking around around and I want to convert my single headlights into composite style.
I have a '93 Sierra 2wd.. I'm pretty sure that I can find all the lights and a grille and whatnot at my local salvage yard. I also found a wiring harness at LMC trucks that will keep the low beams on when I switch to high beams for $30..so I might just order that...or also grab the wiring for the ones when i go get everything.
Will the grille fit flush? I'm thinking of ordering a chrome grille off of LMC truck also, and just getting the lights, mounts, and stuff at the salvageyard.
My brother said that i'd need to order some radiator support thing? which he said was about $50. anythoughts?
93Sierra is offline   Reply With Quote
Old 07-04-2008, 11:08 PM   #2
93Sierra
93Sierra's Avatar
Re: Help with single headlight grille to composite
Any help?
1993 GMC RCLB | Arrival Blue | Leveled | Debadge | Demold | Colormatched | Roll Pan | W/t to Composite grille conv. | SOLD
2008 Chevy ECSB | Line-x | AVS | 3/4 Debadge | Z71 | Blackbear tuned | 35% Roll Ups | 2010-11 HD front end swap swap coming..
Old 07-05-2008, 09:33 AM   #3
MonteSS454
MonteSS454's Avatar
I don't think you'd have to change your radiator core.
MonteSS454 is offline   Reply With Quote
Old 07-05-2008, 09:40 AM   #4
I know folks to go the other way, composite to real headlights and don't remember them needing a core support. Unless someone else chimes in, the best I can think is that no you don't need it, but check while your stripping parts and see if there is anything that is mounted/welded to the composite core support that you don't see on the regular support.
Good luck and keep us informed in how it worked out for you.
Old 07-05-2008, 10:02 AM   #5
93Sierra
93Sierra's Avatar
Alright. Thank you MonteSS454, and Palf70Step =] I'll try to tell you how she goes.
Old 07-08-2008, 07:38 PM   #6
Jeep & GMC
I've never even looked at how the grill is mounted on my trcuk, but I saw this and thought it might help. This place also sells the complete kit with grill and headlights, I just couldn't find it right away.
http://www.mrtaillight.com/product_i...bf68f5e459b69a
Jeep & GMC is offline   Reply With Quote
Old 07-08-2008, 11:02 PM   #7
bwood
bwood's Avatar
Check out http://www.jegs.com/i/Anzo/018/111004/10002/-1 . I put a set of these in my 98. They come with bulbs, headlights and mounting/adjusting assembly. The bulbs a low end, I put a set of Sylvania Silver Stars in.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 07-09-2008, 09:24 PM   #8
Storm Chaser
Storm Chaser's Avatar
I'd bet the core support doesn't need changed. When I started out on my crew cab project, I had just the single headlight on each side. Then I switched to the dual setup (sealed beam, not composite) and all the threaded holes were there. If I remember correctly, it seems someone told me that the composites and the quad sealed beams were interchangeable, as far as mounts go.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 07-09-2008, 10:17 PM   #9
93Sierra
93Sierra's Avatar
Okayy. thanks everyone for the input. Jeep & GMC thanks for that site. I think that those could come in handy.
Old 07-09-2008, 10:40 PM   #10
Jeep & GMC
The owner of that site has a cool diesel suburban and hangs out on the 88-98chevy section of the dieselplce.com
Hope it goes well, post some before & after pics.
Old 07-10-2008, 09:13 AM   #11
93Sierra
93Sierra's Avatar
oh nice. I'll check that site for some fun. I got distracted on another project for now...Getting the bed off so I can do my cab corners. I will put some pics up when I get into the new headlights/grille though.
Old 07-16-2008, 10:49 PM   #12
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
http://www.fullsizechevy.com/forums/...98-2000-a.html
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 07-17-2008, 10:50 AM   #13
93Sierra
93Sierra's Avatar
Originally Posted by ClemsonChevy View Post
Thanks! That was the best help I've gotten =]. I'm bookmarking that one.
Old 07-17-2008, 02:58 PM   #14
Swed-Chevy
Swed-Chevy's Avatar
Thanks,I,m also bookmarking these links
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E.
GMC Sierra Custom C1500 1983.
Oldsmobile Dynamic 88 -65.
Volvo V70 -02 and BMW 523i T -99.
Harley FXDF -08 and Harley FXDB -10.
Honda Dirtbike Dominator -97 and a couple of tractors.
Swed-Chevy is offline   Reply With Quote
Old 07-17-2008, 04:45 PM   #15
ClemsonChevy
no problem!
95 2500 350 w/ 3.73
Old 07-17-2008, 07:55 PM   #16
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
You don't have to spend the $30 on that "Hi 4" conversion kit, it's fairly easy to do with parts store stuff, and from what I hear the kit is not as good as a relay. I think I can get the relay number off mine and all the wiring info, when you get ready.
TennesseeZ is offline   Reply With Quote
Old 07-17-2008, 09:50 PM   #17
93Sierra
93Sierra's Avatar
Yeah, that would be great =] I'll let you know!
