67-72 vs 73-87 lower control arms
are they any different? i know that the crossmembers are interchangeable, but are the lca's interchangeable? i bought some lower bag brackets that were said to be made for 67-87 c10's, but when i got them, they didn't line up at all on my control arms, they were short about 1". here is the ebay link: http://cgi.ebay.com/ebaymotors/ws/eB...m=330264835054
soon to be bagged64sub
Re: 67-72 vs 73-87 lower control arms
I would think they would work. You should find out soon cuz the guy you bought them from frequents this forum.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
#3 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
One day...
![]() Join Date: Apr 2008
Either or, they are similar concept just to keep the bag from rubbing. I would use the plate verses the cup myself, it looks cleaner and bolts to the control arm. But thats just my opinion
hey dubdeuce80,
I'm who you bought those plates from. I'm also curious as why they didn't fit. You are the first I've run into this issue with. Whatever I can do to help just let me know. josh |
There has been lots of talk about that subject. The plate wont let it go as low. So Ive heard. Other than that theres nothing wrong with it.
One day...
Yea knew it wasnt much, depending how my truck sets i may use 8'' pipe and modify lower arm to get the stance i want
#10 | |
![]() this sides fine... ![]() but not so much on this side ![]() i'll be doing some heavy modifications to the crossmember anyways, so i'll be raising where the upper plate mounts while i'm at it, similar to the red rocker i believe it was Last edited by dubdeuce80; 09-04-2008 at 11:31 PM. |
hmmm, somthing looks strange, but can't really tell by the angle of those pics. That indentation in the plates should be where the shock mount is. They should be positioned like this pic.
can you get a pic with out the plate on your lower arms?
I also noticed jlaird has a pair of lower arms and plates for sale on ebay, maybe you guys could work out a swap if your arms won't work. here is a LINKY
#13 |
Jon@AirRideTech
the control arms are the same from 63-87 only thing that changed are the ball joints. As for plate vs cup on our standard cool ride we use a lower cup style bracket and on our tubular arms we use a flat plate....
#14 |
if you look at the pics something is different.............
![]() ![]() Last edited by joe231; 09-05-2008 at 09:40 AM. |
#15 |
Not to hijack, but will these plates work with a '66?
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
#16 |
#17 |
Java Mechanic
Your lower arms do look slightly different, but that could just be the pictures.
I have a set of 3/4 ton control arms off an 84. When I get home I will have a look at them and see if that clears anything up.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#18 |
alright here are a few more pics...
![]() lined up via sway bar holes: ![]() lined up via the edge next to the shock mount: ![]() lined up via the edges: ![]() and the gap left underneath: ![]() |
#19 |
I'm just glad to be here!
dubdeuce80 - Do you know the exact year of the LCA's that you have??
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#20 |
One day...
Yea man definatly, Thanks
#21 |
Correction . . ..... BJ's & bushing style/mount.
#22 |
well since we never did figure out what the problem was, i decided to pick up some '69 lcas...except it kinda came with the rest of the truck
![]() i swapped out the suspension that was in it (6 lug) for my old one. i'm gonna clean up the lca's from this '69 and use those since the plates i bought work with them, gonna be fun ![]() ![]() Last edited by dubdeuce80; 09-09-2008 at 07:29 PM. |
#23 |
love those wheels!
#24 |
Whatever happened to this problem with the plates? did it ever get resolved?I got an 86 SWB and I have the same problem, plates just do not fit. I wish I would of known of this before I bought them, but it does say on ebay it will fit 67-87 LCA's?
GROUND ZERO IS R LIMIT ![]() |
#25 |
like i said in the above post, i picked up a '69, and both the upper and lowers are completely different than the ones on my '80. once i get the balljoints removed (probably sometime this weekend) i will take a side by side picture of both lowers
