Old 03-03-2009, 11:07 PM   #1
Strodder
Daring to be Different
Strodder's Avatar
Got 2 Questions
First question is about the hump in the floor on a 65. Is there a low & high hump. If so what's the difference? Is one for Automatic and the other for stick shift? I'm using a 700R4 would the low hump work?
Second one is what under bed gas tank do you guys recommend? I just saw that LMC has a 21 gallon kit for $199.00. Or would you look for a used tank, and what would you use?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-04-2009, 12:15 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Got 2 Questions
Yes there is a low and high hump, although I am not sure exactly what trucks they came on. My '60 GMC has a high hump even though it is 2wd and has a 3-speed on the tree. I figured the high humps normally came on trucks with the SM-420 or 4 -wheel drive...
Anybody else know for sure?
Old 03-04-2009, 01:30 AM   #3
Captainfab
60-66 Nut
Re: Got 2 Questions
I'm not sure what dictated low or high hump. My '66 Burb came originally with a powerglide, but now has a TH400. Even though it is moved ahead a little, I think there would still be room in the stock location with a low hump.
The '69-'72 Blazer tank kits are a pretty good deal. But since your rear frame is a '73, you should be able to use a '73 and up Blazer tank, or even a '73 and up Suburban tank.
Old 03-04-2009, 01:38 AM   #4
65VOL
65VOL's Avatar
Re: Got 2 Questions
The humps are associated with the type of transmission the vehicle was outfitted with. The high humps were in floor shift and all 4x4 models while the low humps were in 2wd column shift models.
65VOL is offline   Reply With Quote
Old 03-04-2009, 06:13 AM   #5
LILRED66
LILRED66's Avatar
Re: Got 2 Questions
As stated above the low hump came on the column shift trucks, ie automatics and three speed on the column and the high humps came on the 4-speed floor shift (SM420 & SM465) transmissions and all 4x4 trucks, to accommodate the transfer case shifter.
LILRED66 is offline   Reply With Quote
Old 03-04-2009, 10:06 AM   #6
Strodder
Strodder's Avatar
Re: Got 2 Questions
Thanks guys. I just wanted to make sure when I put the engine & trans in it will fit. I was thinking the low hump was for stick shift, and the 700r4 wouldn't fit. Thanks for answering my question about the hump.
I still need input on the gas tank.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-04-2009, 10:42 AM   #7
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Got 2 Questions
Strodder, didn't you "lower" the cab when you mounted it to the 73 frame? If you did there "might" be some clearence issues with the trans tunnel. Keep that in mind when you go to put in the motor/trans set up.
Good luck with your build.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-04-2009, 11:51 AM   #8
joe231
joe231's Avatar
Re: Got 2 Questions
the gas tank question is kinda a loaded one.....
what do you want in a tank? how much do you want to spend?
you can get a full custom tank for $350-$500, or as Captain mentioned a '73-'91 blazer or burb tank should go in fairly easy.
That LMC tank should work, but might hang kinda low
all kinda depends on what you want to accomplish
CHEVY ONLY
Old 03-04-2009, 12:18 PM   #9
Strodder
Strodder's Avatar
Re: Got 2 Questions
The front of the 65 frame goes back to the middle of the 65 body where it is still level. The 73 frame tilts up where the rear body mounts go. That's why I channeled the back of the cab. But the front shouldn't be effected. Besides I added a 1/2" shim to the front body mount so the fenders will line up correctly. Good thought though.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-04-2009, 12:26 PM   #10
Strodder
Strodder's Avatar
Re: Got 2 Questions
Yea I was wondering that about the LMC tank hanging too low. Especially if I'm going to Bag it. The Truck Shop has a tank kit for the rear under bed also for $190.00, but it doesn't say how many gallons it holds. It's on page 79
http://www.scribd.com/full/5722345?a...jcbazlklxtunnw
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-04-2009, 12:29 PM   #11
Strodder
Strodder's Avatar
Re: Got 2 Questions
I'll look into those tank too. Thanks
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-04-2009, 12:39 PM   #12
Strodder
Strodder's Avatar
Re: Got 2 Questions
I just looked up the 73 gas tank. It's a 25 gallon. If I make up the kit it will only cost $124.00 with the tank, sender & straps. I wonder if the 25 gallon tank will sit even lower that the 21 gallon one.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-04-2009, 09:16 PM   #13
Strodder
Strodder's Avatar
Re: Got 2 Questions
I went to the local Pick A Part today. I found a 77 Blazer that still had a gas tank in it. (They usually take the tanks out, and crush them) They wanted $49.00 for it. I'll go back tomorrow to get it. After I went home to get my tools it looked like it was going to rain, and it did. That's why I'm going back tomorrow. It also had the exact front 60/40 red front seat from a newer year. They want only $39.00 for the seat. It's in perfect shape. I'll post picts on my build thread. Hey guys, thanks for all your help
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
