08-17-2009, 09:28 PM | #1 |
look what came in the mail! UPDATED!!!
my kit came in the mail today, 4.5/6 mcgaughy's drop kit. 2.5 inch drop spindles, 2 inch drop coils, flip kit, c-notch. and for shocks a got 4 bell-tech nitro drop 2s.
before i start the drop , does anyone have any tips or anything that will help? thanks Last edited by dbmx66; 08-18-2009 at 11:17 PM. |
08-17-2009, 09:43 PM | #2 |
67-72 parts collector,…
Re: look what came in the mail!
Take your time, take pics,... and look at all the associated parts for defects and wear.
Nows the time to replace any bad brake or steering components. Also use jack stand or a lift, and eye protection when cutting or grinding. If you have any questions along the way,... don't be afraid to ask. Welcome to the board. Also,... what is this drop going on? .
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-17-2009 at 09:44 PM. |
08-17-2009, 11:00 PM | #3 | |
okay, i'll have to check the steering. from what i know its fine. but its doesnt hurt to check again i guess. the drop is going on a 78 chevy c10. thanks man! |
08-17-2009, 11:02 PM | #4 |
by the way, do you have any tech articles or are there any other previous threads on how other people put there kits on. just so i could check them out. thanks
08-18-2009, 12:16 AM | #5 |
6.0 powered square
hears a few
http://73-87.com/7387garage/chassis_.../box_drop2.htm http://73-87.com/7387garage/chassis_...nsion_drop.htm
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
08-18-2009, 08:09 AM | #6 | |
08-18-2009, 08:15 AM | #7 |
Tot Roddin'
Good luck with the install as I recently did a similar install on my '69. As long as you have all the pieces the install should be a breeze. Keep us posted on your progress.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 08-18-2009 at 08:15 AM. |
08-18-2009, 09:12 AM | #8 |
08-18-2009, 09:29 AM | #9 |
Start soaking the assorted threaded items now w/some penetrating oil so that when you're ready to start the parts swap, you've free'd-up any potentially stuck hardware (which is always better than fighting it for 1/2 the day).
Take pics so you can reference how things were (just in case).
08-18-2009, 09:41 AM | #10 | |
thanks. |
08-18-2009, 09:42 AM | #11 |
how much did it come out to?
iv been wanting to do that same drop |
08-18-2009, 11:04 AM | #12 |
well, i bought it through stylin' trucks, there having a sale on alot of things now. i got the drop kit for $562.49 and all the shocks for around $180 everything came to around $800 with shipping included.
08-18-2009, 11:46 AM | #13 |
I'm a big "neverseize" user also. I use it on all my bolted connections.
08-18-2009, 11:51 AM | #14 |
08-18-2009, 12:13 PM | #15 |
The only advice I have is to box those parts back up and send them to me. I'll PM you my address.
Seriously, take measurements before you start. What I do is write the initial measurements from the ground to the wheel arches on a small piece of painter's tape and stick it to the fender/quarter panel above each wheel opening (less chance of losing the measurements).
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
08-18-2009, 01:26 PM | #16 | |||
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 08-18-2009 at 01:28 PM. |
08-18-2009, 11:05 PM | #17 |
front suspension is finished, pic up soon.
08-18-2009, 11:33 PM | #18 |
overall the front was pretty easy except both the blown lower ball joints which were total b*tches to get out. it took a lil under 3 hours just do do front. we will be doing the rear either thursday or friday.
took lots of pictures too front suspension before rear suspension before stance before the drop front left before new parts. blown lower ball joint! bad time for a blown lower ball joint. had to take the lower control arm off to get the ball joint out. everything almost back together. yes i know i need new rotors! |
08-18-2009, 11:33 PM | #19 |
my brother putting a brake caliper back on.
need new tie-rods front done! still on the jack stands. after front drop, no jack stands. same as above ^ after front drop side view crazy rake until we finish the rear drop. front view. in this pic you can get an idea on how much of a rake there is. |
08-18-2009, 11:37 PM | #20 |
by the way, the steering column, booster brake and master cylinder are fresh too!
08-19-2009, 12:03 AM | #21 |
I really hate wet sanding!
you would see a lot more rake if you had the weight of the drive train and front clip on it! I did this drop on an 84 I had a few years ago...don't be suprised if you intend on using the stock ralley that they contact the control arms...you will have to do a bit of grinding on them if want to keep wheel weights on the fronts...lol. Good luck with your build!
Get several buddies around to help with the rear, getting the rear end on top of the springs is a giant pita! |
08-19-2009, 12:06 AM | #22 | |
08-19-2009, 01:55 PM | #23 |
Tot Roddin'
Nice work!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-19-2009, 02:27 PM | #24 |
08-20-2009, 09:57 AM | #25 |
cool!
