Old 01-10-2010, 07:22 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
1973 hand throttle control-is it 4x4?
I bought a dash mounted hand throttle from a 73 2wd Cheyenne super. This piece mounts at the bottom of the dash above the gas pedal. the bracket bolts to the dash and the gas pedal, and you turn the knob which operates a cable that pushes down on the gas pedal, giving you a manual throttle-it's factory but I have never seen one before and was wondering what something like this may be worth? is it an rpo for 4x4"s? also this truck had a G86 locking diff and a RPO ZN9 opt. axle ratio#3.....anybody know what gear this could be? thanks steve
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 01-10-2010, 07:27 PM   #2
fbird68
fbird68's Avatar
Re: 1973 hand throttle control-is it 4x4?
Hey Steve. I have a factory installed throttle control like the one you are talking about on my 71 C10. As far as what it's worth. I can't even tell you what the thinking was behind the design!? I could see it's worth if you had a PTO on your truck but otherwise.....I don't know.
Richard
STR Restoration and Customs
1971 C10 Custom
1964 Impala 2dr Hardtop
1965 Parisienne CS
1937 Nash Lafayette
1947 Willys CJ-2A
fbird68 is offline   Reply With Quote
Old 01-10-2010, 07:49 PM   #3
into69z
into69z's Avatar
Richard
is yours at the bottom of the dash on your 71 or is the knob in the dash bezel?...Steve
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 01-12-2010, 04:29 PM   #4
Conundrum
Conundrum's Avatar
I was wondering what this was for awhile back as well.
Mine was in a 74 3/4 ton 2wd.
Here's the link
http://67-72chevytrucks.com/vboard/s...d.php?t=358305
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 01-17-2010, 02:53 PM   #5
fbird68
fbird68's Avatar
Mine is on the upper right right corner of my dash bezel below my wiper switch. Again, it is on a 71 C10 so won't be exatly the same but you do turn it to increase rpm.
"Poor mans cruise" is my guess on my truck beacause it was a 250ci w/350 auto combo.
Richard
1971 C10 Custom
1965 Parisienne CS
1937 Nash Lafayette
1947 Willys CJ-2A
