07-08-2010, 12:33 AM | #1 |
new donor and new crew
i beleive i found my new donor for my 74 c10. and i think i got a new work crew too.
DONOR IS 94 Z28 LT1 MY CREW GOTTA MOLD THEM EARLY
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS |
07-08-2010, 07:00 AM | #2 |
Re: new donor and new crew
I rode in a car just like that many times. That LT1 pulls hard! Should be a good swap. Keep us updated. I agree about your young crewmember, mine is 2 1/2. He already is a car/truck nut!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
07-08-2010, 08:46 AM | #3 |
Slots go on anything!
You are going to really like the swap. I am getting great mileage, and have pretty decent power, too (it will kill the right rear tire at will.....). Look into getting an Alan Groves accessory setup so you won't have to notch the frame. I bought my truck with the swap done, but I have gone back through most of it. If you have any questions, feel free to give me a shout.
1974 Jimmy- 5.3/4L80e/NP241 |
07-09-2010, 09:36 PM | #4 | |
07-10-2010, 01:34 AM | #5 |
Whooow!! This lt1 isnt a walk in the park. I beleive all i have left is the starter and knock sensor plug. Photos tomorrow.
07-10-2010, 08:04 AM | #6 |
If you are running A/C, it may hit the frame in the stock F-body location (lower right). The A/C compressor in the stock location also requires that the right side engine mount be moved back, to clear teh compressor. Sounds like you have it in though. Where are you going to mount the PCM?
07-10-2010, 10:14 AM | #7 | |
Still plays with trucks
I have put LT1's into a 91 RS Camaro, 67 Chevelle, 66 El Camino and a 68 Jaguar XJ6. Great engine as long as you have a vented Opti and a good water pump.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-10-2010, 12:00 PM | #8 |
This is true. They are a little harder to find, and I think the Groves brackets are probably cheaper, to boot. They use a Sanden style compressor, and mount the alternator and a/c compressor up higher.
07-11-2010, 09:57 AM | #9 |
MOVING ALONG
07-11-2010, 10:00 AM | #10 |
FINALLY GOT IT!
07-12-2010, 11:13 AM | #11 |
Why don't you try to tuck that Camaro K-member under your truck intact?
What is the track width on that vs. the truck?
07-12-2010, 11:42 AM | #12 |
Idk about that 68TT. I believe its to narrow. I never really checked it. Hey jonboy. What did you do for a driveshaft? And did you use the truck motor mounts?
07-13-2010, 12:03 AM | #13 |
its finally off of the sub frame. sub frame back on the car so scrap yard here we come. pics tomorrow.
07-13-2010, 08:52 AM | #14 |
The driveshaft was replaced before I got the truck. On your LT1, what accessories do you plan to run? If you remove the A/C compressor, you can rotate the clamshell forward, and use it with the stock frame mounts in your '74. There is an extra boss cast in the block. (I found this out the hard way in a '94 Roadmaster). the mounts will be in the same location on both sides. IIRC, the 4l60E is really close to the same length as the TH350 with a long tailshaft, so your existing driveshaft may work, but you will need to use the yoke that corresponds to the transmission you are using.
You may want to check out these sites also: http://www.alangrovecomponents.com/ and www.lt1swap.com .
07-13-2010, 11:50 AM | #15 |
Make sure you snag the rear disc setup with backing plates before you scrap it. They sell for a pretty good price used. Calipers have the integral parking brake that makes the retrofit to older cars much easier.
07-13-2010, 04:56 PM | #16 |
IT Guy/ Father/ Chevy lover
Any picks of the 66 I LOVE 66 ELCAMINOS
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
07-13-2010, 06:11 PM | #17 |
Sorry, I sold the Elky in 2003 and don't have any pics of it handy.
Here are a couple I had on hand of the 67 Chevelle. Engine is quite dirty as the pic was taken while I was doing the body work. Big time sleeper with 12" front & 11" rear disc, huge sway bars, heavy springs, Koni red's and poly everywhere. I kick myself every time I think about having sold it. I did get $8k out of it in primer with the body work done but the interior needing completely redone so at least I didn't lose money on it too. Lost all the pics of the 91 RS & Jag due to a hard drive crash. Can't find the back-up discs to save my life.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 07-13-2010 at 06:12 PM. |
07-13-2010, 11:35 PM | #18 |
thanks for all the help jonboy. im not sure where im going to put the pcm. where did you mount yours. how much of the wiring to i need to keep? do i need to go all the way to the fuse block?
07-13-2010, 11:35 PM | #19 |
yea i plan on take off the rear diff when i get to the salvage. im thinking about putting it in my regal.
07-14-2010, 11:53 AM | #20 | |
Only the pinion bearing needs changed. For some reason the depth is different between a G-body & F-body but the bearings with fit either pinion gear. The 4th gen trailing arms are a nice upgrade for the G-body too. Better bushing design so grab those too.
07-14-2010, 12:00 PM | #21 | |
There isn't much length to the stock harness since the PCM is mounted to the inner fender so you are kind of limited as to where it will fit without a bunch of wire extension & soldering. I blended two harnesses together to get the PCM under the dash in the 91 RS swap. Quite a lengthy process but worth it to clean up the engine compartment.
07-14-2010, 12:18 PM | #22 |
They used a Painless harness in mine, and shoved the PCM under the dash. I moved it back under the hood, and mounted it on the left fenderwell. I would keep as much of the harness as you can.
07-14-2010, 12:48 PM | #23 |
I used the Painless harness in the the Chevelle. It was good quality but the wire routing was truly painful to look at. I made my own out of stock harnesses after that one.
07-14-2010, 12:52 PM | #24 |
Mine was a painful harness when I got it too. I think there was an engine fire, and the harness took the brunt of it. Looks nice now, though.
07-14-2010, 02:40 PM | #25 |
you guys are a great help. i will have a million more question during this process. heres another 1 now. do i need to keep the fuse panel.
