Old 04-28-2011, 09:46 PM   #1
spazzyfry123
spazzyfry123's Avatar
Parking Brake Questions
I have a '68 SWB. During the restoration, never really bothered with the parking brake system.
Can anyone help me out with part numbers on everything needed for the system? From the handle all the way to the drum.
I was planning on purchasing through LMC, but the diagrams and descriptions have confused me even more. I've noticed that NAPA carries the cables as well.
I need to get back under the truck and double check but all I need is...
40" cable + intermittent cable + handle that goes under the column
Right...?
Thanks in advance for the help.
-Tyler
Edited by Forum Staff!
spazzyfry123 is offline   Reply With Quote
Old 04-28-2011, 11:41 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Parking Brake Questions
handle is attached to the main gear system with the pedal, then the main line that runs from that through the firewall and to the frame (hardware there to mount it). Then the one that runs from there to the back....that meets the one that runs to the drums both sides of the rear axle (hardware there to mount it)
that's my recollection....maybe someone else can chime in w/ part numbers...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-29-2011, 10:29 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
this picture may help ya....usually they are worth a 100 words...and that's close to what VA72C10 worte (BTW...67/68 had the hand operated ebrake, 69-72 has foot operated ebrake)
Couple things about where to get them....first off you may want to look in the parts board for folks parting trucks (make sure you specify if your truck is short or long bed), or I think you can order complete from inlinetube.com
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-29-2011, 01:23 PM   #4
spazzyfry123
Thanks for the help, guys!
Yowza... Inline wants $200+ shipping for the set. I was thinking <$100... I really need the parts, well, today. Let me see what the local parts store can do.
I guess I just don't understand the parking brake system. What's the purpose of the lines going toward the rear passenger side and in front of the firewall. I just would have assumed it would go straight from handle to drum. Is it possible to do just that?
-Tyler
Old 04-29-2011, 01:29 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
maybe an aftermarket system might work that way, but the factory system mounts to the frame for strength and mounts at the rear to the piece so that both sides pull evenly....
Old 04-29-2011, 01:37 PM   #6
spazzyfry123
This is what I'm looking at...
https://www.napaonline.com/Catalog/R...29&Ntk=Keyword
Out of those, all I would need is part numbers...
UP 92443
UP 92416
And would this one be what connects the handle to the intermediate?:
UP 92449
If so I'm on my way to NAPA if that is all I need.
Old 04-29-2011, 01:40 PM   #7
spazzyfry123
It's more of a "let's pass inspection!" type deal than a "I really care about the parking brake system" type deal
But I don't want it breaking after spending all day wiring this up.
Old 04-29-2011, 01:40 PM   #8
leddzepp
Moderator
leddzepp's Avatar
go to carquest if you have one in your area. a knowledgeable person there will have everything you need.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-29-2011, 02:09 PM   #9
spazzyfry123
I would but the nearest one is about 30-45 minutes away when NAPA is about 3 minutes away.
Old 04-29-2011, 08:29 PM   #10
pritch
pritch's Avatar
Same with me. I still go to Carquest.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 05-02-2011, 05:50 PM   #11
68 IRON
68 IRON's Avatar
Spaz, theres a guy parting a 68 in the parts forum. Take a look he might have the whole setup.
68 IRON is offline   Reply With Quote
