What??
Re: What??
4.3? i donno could be just another crazy, could be a guy that knows his stuff but has trouble explaining.
Re: What??
4.3...I understood the geezer perfectly
#4 | |
Re: What??
Terrible explanation. |
Re: What??
Maybe you could use the other 2 cylinders for an onboard compressor.......
A smith compressor uses a ford 302 with one bank to run and one bank as a compressor.
Some say "The glass is half empty." Some say "The glass is half full." I say "the glass is twice as big as it needs to be, chop it off!!! |
BAD BOW-Silverado XST
Re: What??
Not bad for a starter project.
Re: What??
call him an ask him if he can unblock the cylinders and throw in two more pistons for you HAHA
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: What??
GM must have ran out of 4.3 blocks when that truck was built so they just used a 350 block and modified it.
![]() ![]() Still a nice truck though.
http://www.cardomain.com/id/rcflyer1234 http://www.youtube.com/user/liftedtruck77 |
Re: What??
Has anyone called this guy? I live in South Austin. I may have to see this one of a kind engine for myself;-)
#10 | |
Re: What??
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Re: What??
The 4.3 has the same bore/stroke as a 350. I remember when they first came out all the talk about it being just like a 350 with the rear two cylinders cut off.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
Re: What??
I worked with a guy that swore up and down that was how GM made these.Dude was always right so you couldn't correct him.You know the type.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
#13 |
78K & 79C Jimmys
Re: What??
thought the 229 was with two removed......never heard or seen this
took out a 229 put in a 350 quite ez can't just be loose floating parts?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 07-28-2011 at 10:53 AM. |
#14 |
Re: What??
A 4-3 is a v6 block, simple as that, there are not any "open" cylinders.
The '85-up 4.3L V-6 has the same bore and stroke as a 350 V-8 (4.000x3.480), and takes the same pistons, cam bearings, main bearings, valvetrain parts, timing cover, oil pump, and front dress.
#15 |
78K & 79C Jimmys
Re: What??
lookin it up the 229 stopped and changed to 262? in 85
mine was 81 sounds like the earlier one had even more in common, in parts
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#16 |
Re: What??
The 229 has a bore/stroke the same as a 305 whereas the 4.3 has a bore/stroke the same as a 350. 305 parts are interchangable with the 229 and 350 parts are interchangeable with a 4.3.
#17 | |
78K & 79C Jimmys
Re: What??
I had always just heard and compared it to a V8 with two cylinders removed
#18 |
Re: What??
I emailed him....
#19 |
Re: What??
#20 |
Re: What??
#21 |
Re: What??
Get an address or phone number. I'll drive by and take a pic of the mysterious engine.
#22 |
78K & 79C Jimmys
Re: What??
http://67-72chevytrucks.com/vboard/s...d.php?t=476734
he's looking for picks of the power steering for that block
| Bookmarks |
