Old 01-07-2012, 05:26 PM   #1
Livrat
Member #1049
Livrat's Avatar
Optional/Aux Hi-note horn
I do believe this was a 69-72 only optional Hi-note horn, (I have only seen the bolt hole on the core support for it on those years)
Media blasted,painted and tested (after blasting), with wire pigtail.
$50.00 shipped
Livrat is offline   Reply With Quote
Old 01-07-2012, 07:07 PM   #2
bntmotorcycles
Re: Optional/Aux Hi-note horn
got any extra green wires?
bntmotorcycles is offline   Reply With Quote
Old 01-07-2012, 07:25 PM   #3
Livrat
Member #1049
Livrat's Avatar
I may, I will look at the shop Monday and let you know
Old 01-08-2012, 09:53 PM   #4
Livrat
Member #1049
Livrat's Avatar
Made it to the shop today. looks like I can help you out.. I have both a short one and a long one.. Let me know if one will work for you
Old 01-09-2012, 10:27 AM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
I am interested. How can you tell the difference between this and a regular horn? Do you know the option code? Would it be listed on the SPID?
Never seen one before.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-20-2012, 04:42 PM   #6
bntmotorcycles
I need the long wire. How much shipped to 46110
Old 01-20-2012, 08:18 PM   #7
Livrat
Member #1049
Livrat's Avatar
How does $10 shipped sound?
Old 01-09-2012, 11:53 AM   #8
Livrat
Member #1049
Livrat's Avatar
The difference is the "sprial" is opposite of the standard horn as it is counter clockwise and it has an "H" cast into the bell they are mounted just outside of the headlite hole in the core support and connected with the green jumper wire.
Sorry I do not know the option code, I have never noticed it it was listed on the SPID.. (never pay attention to them).
Maybe someone could chime in and confirm if they are listed on the SPID or not??
Old 01-09-2012, 10:30 PM   #9
chipflyer
chipflyer's Avatar
Yep, "dual horns" was a factory option, Its listed as U08.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 01-09-2012, 10:34 PM   #10
Livrat
Member #1049
Livrat's Avatar
Jeff
Jeff, Would you happen to know if it was 67 thru 72 or just a couple of years?
Old 01-09-2012, 10:41 PM   #11
RenoKeene
Florida Edition
RenoKeene's Avatar
I may already have one on my parts truck (custom camper), if not I will take this one. I will let you know in the am.
Old 01-09-2012, 11:49 PM   #12
chipflyer
chipflyer's Avatar
Without doing some checking I think it was available from 67-70 but not sure about 71 or 72.
Old 01-20-2012, 05:18 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Both 72's I have owned have had the dual hi/lo horns.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-20-2012, 07:36 PM   #14
jaros44sr
jaros44sr's Avatar
Hey, did this become available again, if so ill take it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 01-20-2012, 08:20 PM   #15
Livrat
Member #1049
Livrat's Avatar
Jim, Yes it is available. Do you still have my paypal info?
Old 01-20-2012, 09:12 PM   #16
jaros44sr
jaros44sr's Avatar
Should, put it in my contacts Mark! But, i will let you know if it is not there
Thanks, i missed this last time around.....
SAFETY FIRST
AS usual, off topic
Jim
