07-24-2012, 08:15 PM | #1 |
GMC and Chevy TF doors slightly different
I just test fitted my new door for my truck. I came from a 55-57 GMC and is a tiny bit different. The hinge bolts take a different thread pitch and the interior door panels have a different size screw. Are there any other differences that I should know about?
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
07-26-2012, 02:27 PM | #2 |
Re: GMC and Chevy TF doors slightly different
58 & 59 chevy and gmc trucks are far superior and had all the bugs worked out of the inferior 55-57 trucks
chevy and gmc changed the door hinge bolts in 58, same doors 55-59 they probably stripped a few of the coarse thread bolts in production and changed to fine thread bolts. don't know about the trim screws though, they only sell one size for 55-59 trucks
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-26-2012, 05:42 PM | #3 |
Ogre. I hope your correct about the door trim screws being all the same, I not long ordered a set from Classic Parts.
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
07-26-2012, 06:06 PM | #4 |
Interesting about the hinge bolts. My '57 has fine thread bolts on both doors. The driver's door is original and the original passenger's door, which I removed, also had fine thread. The replacement RH door is from a '55 'burban and I thought someone had hacked it up by putting coarse thread bolts in so I cut the plate with the fine nuts out of the original door and welded it into the new one.
How about the countersunk screws which attach the inner panel? Is clutch head correct? Or Phillips? I've seen both. |
07-26-2012, 06:28 PM | #5 |
clutch heads were original on the door latches and window regulators - but i never had a door with original door panels not removed so cant call that one either way... had a '59 that had clutch heads and a '55 on the door handles
as for doors - my 55 doors were coarse - 59 fine door strikers (bolted to cab) also changed completely! better design in later years - threads on this changed as well |
07-26-2012, 07:01 PM | #6 |
I was cleaning out the threads on my door hinge nuts last night. They are 3/8-20. The screws that hold on the panel over the window regulator and door latch accuator are phillips head. Door internal screws were clutch heads.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-27-2012, 09:56 AM | #7 |
Thanks for all the great responses. I am out of town so I can't post pics. It sounds like a year thing and not a brand thing or it could also be that Chevy and gmc may have been made in different plants which could lead to slightly different processes. On my original 59 doors the screws were just like the ones classic parts sells (big like a 20 shaft size as previously mentioned.) On this door they are much thinner like a 10 or 12 shaft size. I will post pics when I get home.
07-27-2012, 12:31 PM | #8 |
No need to put them back in, I replaced them with regular hex head bolts.
Retired and too busy to work. |
07-27-2012, 04:59 PM | #9 |
Brain fart, the bolts are 3/8-24 TPI.
07-31-2012, 09:56 PM | #10 | |
