Old 08-01-2012, 02:16 PM   #1
ts71281
Does anyone here run Sanderson BB8 headers on their big block trucks?
I am interested in buying another set of headers for my '70 C10 with a 468. The current supertech headers are junk and are coming out with a sawzall.
I want to know how much clearance the BB8's have around everything, and if they're going to rattle on any suspension parts/frame/motor mounts/etc.
I have a 4 speed in my truck so I need to keep in mind that the #7 primary needs to be enough forward I can run the block mounted ballstud from the block to the frame without the headers hitting. Does anyone have pictures of the BB8's or other sanderson headers installed?
Thanks,
Joe
ts71281 is offline   Reply With Quote
Old 07-21-2014, 12:07 PM   #2
ts71281
Re: Does anyone here run Sanderson BB8 headers on their big block trucks?
Can someone help me with this? I'm still in the market and I want to get back behind the wheel of my c10
Old 07-21-2014, 04:00 PM   #3
jeh
jeh's Avatar
Just installed mine this weekend. They are Sanderson BB8
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 07-21-2014, 04:03 PM   #4
jeh
jeh's Avatar
Here's another pic, I did have to grind a little "half moon" in the right frame rail for a little extra tube clearance. I also have Performance Online motor mounts, not sure if you have factory BB mounts but that might make a difference.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-22-2014, 10:15 AM   #5
4oldcars
4oldcars's Avatar
My experiance with Sanderson was on a big block. Six months after install a weld broke. I contacted Sanderson and they said so what. They won't get any more of my money.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 07-22-2014, 10:26 AM   #6
ts71281
Jason, thanks for the pictures. I do have the correct 1970 big block engine towers (perches) and proper motor mounts. I also am running a 4 speed m-20 munice in the truck, so I need to utilize the stock clutch Z-bar location. The problem I'm concerned about is getting the Z-bar to attach to the block without hitting the #7 primary on the cylinder head. I'm running a stock smallblock ball stud which even offsets z-bar back a bit. I do have an original 1970 big block TRUCK ballstud that I would like to mount. It would bring the z-bar perfectly perpendicular as it should, but headers are a concern. I don't want the z-bar rubbing on the primary or soaking in all that heat. Any pictures you could get of your sandersons back where the zbar bracket is would be extremely helpful. A nice bright flash would be a plus.
Old 07-22-2014, 07:44 PM   #7
jeh
jeh's Avatar
What weld broke???
I can take some more pics when I get home from work next week. Sorry about the dark pics, I only had one side of the garage lights on.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-22-2014, 09:59 PM   #8
Fitz
Thanks,
Joe
Aye Aye, Captain! If this isn't a big block there's no such thing and those are Sanderson BB8 block huggers. When I was fitting up the exhaust I had to move the oil filter so I wouldn't have to remove the headers to change the filter. I had already mounted a remote filter so that wasn't much of a problem. As you can see, my truck has a turbo 400 automatic, not a stick. Getting the trans dust shield on takes some fiddling but it does fit.
Fitz is offline   Reply With Quote
Old 07-23-2014, 06:30 PM   #9
jeh
jeh's Avatar
You BB8's don't look like my BB8's......
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-23-2014, 08:08 PM   #10
Fitz
I bought those in 2004 when I started building the truck. They were the second set Sanderson made for the 502/572 heads on a 10.4 inch tall deck block (Stacey David got the first ones for Copperhead). I understand they re-routed tubes on the short deck headers but I have not seen them.
Old 06-02-2015, 08:37 AM   #11
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Jeh, did you have any clearence issues with your oil filter, and can you remove it with the headers in place?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 08-01-2015, 09:27 AM   #12
jeh
jeh's Avatar
Sorry for the late reply, yes I can remove the oil filter with the headers in place. I've been driving the truck some this summer and so far so good with the headers.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 08-01-2015, 10:39 AM   #13
eightbanger
454 MAKES IT ROAR
No worries Jeh,.i bought a set and i'm very happy with the fit, I needed to trim about 1" off the corner of the tranny bell housing on the PS for the collector flange to clear.
