2" and 2.5" lift options?
Doesn't look like tuff country offers a 2.5" kit. I am only going with 33's so a 2.5" is what I'm looking for. I hear such good reviews on the tuff country ez rides so thats what I want to go with question is will their 2" be enough not to rub with 33" on stocker 8" rallys even under mild offroading.
Re: 2" and 2.5" lift options?
A 2" lift with 33's on 8" wheels is plenty. You won't have any problems. I have the same lift, tires and wheels on my blazer and with no problems....I don't have any pictures currently.
please, if you get time put up a picture of your blazer with the 2 in lift and commit on the ride quailty.
thanks |
Yeah, I'd be really interested in seeing that too.
Jerry |
It will be a couple weeks before I can get a picture it isn't at my house. The ride is near stock with 2" tuff country front springs and hydraulic tuff country shocks.
here is my old Jimmy with tuff country 3" and 33x13.50 toyo MT on 15x8
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Man I really thought your Jimmy was taller than that. I thought for sure those were 35's.
Jerry |
#8 | |
if so whats the deal with the 3" rear lift springs being 1.5" from the amount of life the front springs gave? that scared me from tc lifts kinda when i read that. |
Pretty sure he used factory rear springs with a 1.5" block, not 3" rear lift springs too. It just helps to level it out, not lifting the rear as much. Nice ride, by the way!
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400
lol...stalkers
Actually I did install new leafs on all corners. However after I installed it the rear looked lower. After finding the leaf part number for rears it appeared they sent me 2" rear leafs with my 3" front leafs. Instead of me removing leafs, shipping back and getting new leafs I had them send me a 1.5" block kit to correct the height. back to topic.....Not all tires are "true sized" meaning it may say 33x12.50 but not actually be 33" (my toyos were little over 33 and much wider). My advice is find the tire you want, look at the mfg actual specs first, then decide on wheel width and backspacing, then determine what size lift you need to not only clear them at the street driving but also be able to go offroad with them and clear the fender corners.
i'm running Tuff Country ez ride 3" springs on my 86 K2500. clears the 33's with plenty of room,and the ride is not that bad.http://67-72chevytrucks.com/vboard/s...d.php?t=498338
#13 |
I'm installing 2" TC springs right now. I'll post up pics as I go along with before and after measurements. Over in the 4x4 sectioin...
http://67-72chevytrucks.com/vboard/s...d.php?t=547921 Posted via Mobile Device
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
| Bookmarks |
