12-16-2012, 05:08 PM | #1 |
Where to find door weatherstripping
I am overseas and need door gaskets for my 72. I read a few posts about the style GMC Pauls sells but they won't ship to military APO so I need to find another source. Who makes/sells them?
12-16-2012, 05:49 PM | #2 |
Active Member
Re: Where to find door weatherstripping
Maybe Wes at Classic Heartbeat will hook you up.
67 C20 283/4 Speed |
12-16-2012, 06:00 PM | #3 |
summit or jegs has soft seals......good stuff!
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
12-16-2012, 08:49 PM | #4 |
Moderator
I'd try Wes. I believe he sells the same ones GMCPaul does. They clip on, no gluing, awesome part.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-16-2012, 10:37 PM | #5 |
PM me and I will provide you with my address, Have them sent to me, I'll rebox them with a USPS box and send them to your APO as a care package. No Charge- Thanks for your service to our country.
12-17-2012, 05:06 PM | #6 |
If yu are stuck and need them, mid 90's I believe Dodge Dakota will work from an auto wrecker. Might be just as hard to find over there though..
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
12-17-2012, 05:31 PM | #7 | |
The ones GMCpauls carries which are the BEST... are made by precision. Weev-
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
12-25-2012, 01:57 PM | #8 |
Thanks guys, I was on the road and just got home. I'll track some down from Precision.
Don, thanks for the offer but I have to make an order for other stuff as well. Merry Christmas guys. |
12-25-2012, 04:37 PM | #9 |
the boat guy
I've heard stuff from 99 up full silverado-suburban clip right in and are quite a bit nicer than stock. They have the corner molded in and are a little longer so all you have to do is trim them to fit.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-25-2012, 06:58 PM | #10 |
Active Member
I bought mine couple of years ago from GMCPauls. At first the doors were somewhat hard to close so I had to adjust the striker out a little. After a summer they will mold to the door.
Leave a little more than needed at the bottom where the two ends meet. Maybe 1/4 inch. Mine seemed to have shrunk about that much but I think it was my fault for not pushing the corners in all the way. Overall, very pleased with them. I bought window channel kit and seals at the same time and found out that with the cab sealed tighter it is easier to close the door slowly until there's about 6 inches left then push it faster to close it.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
12-25-2012, 10:14 PM | #11 | |
Thank you much for your service. |
02-22-2013, 08:01 AM | #12 | |
Did I order the wrong part? |
02-22-2013, 11:16 AM | #13 |
Moderator
Sounds like it. I believe he carries both kinds.
02-22-2013, 11:23 AM | #14 | |
Active Member
02-22-2013, 05:17 PM | #15 |
Thanks everyone, got the correct stuff on order
