Old 04-03-2013, 01:38 PM   #1
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
66 cab wiring
I am at a loss.
I am working on a friends 66 Chevy truck and I am told that there are differences between the wiring with idiot lights and gages.
The original wiring harness is pretty butchered but may be repairable.
However, the truck had idiot lights and I am now installing gages.
At this point I do not know what I need.
Also, I would love to find an outlet that sells the plug ends so I can replace damaged pieces.
All of this is completely different than the GMC stuff I normally work on.
Any wiring guru's here that can help??
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 04-03-2013, 01:50 PM   #2
1963c-10
1963c-10's Avatar
Re: 66 cab wiring
Im no wiring guru, but I did the conversion in my 63. I used a new wiring harness due to the condition of my OEM harness, but I did research on it before. There are some things that'll change, and some remain the same. The fuel guage is the same. The oil pressure guage will have to be plumbed from the block, and the wires for the sender can be eliminated. The ammeter or voltmeter depending on what you have will have to be wired. And the temp sending unit has to be swapped out and wired. The speedometer is the same as is the turn signals and the cluster bulbs. Tachs had their own wiring harness, so it's completely seperate.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-03-2013, 01:51 PM   #3
1963c-10
1963c-10's Avatar
Re: 66 cab wiring
I think the plastic plugs can be ordered from Obsolete Chevy Parts and I believe Truck Shop in CA has them also.
Old 04-03-2013, 02:00 PM   #4
66-PMD-GMC
66-PMD-GMC's Avatar
Re: 66 cab wiring
Thanks 1963C-10,
I have the harness that comes off the gage cluster.
The oil pressure gage looks pretty straight forward.
I was told the main harness that includes the fuse block is different.
I will check on the plug ends.. thanks again.
Projects..
440CID 2X4 Pontiac
Old 04-03-2013, 04:28 PM   #5
66-PMD-GMC
66-PMD-GMC's Avatar
Re: 66 cab wiring
I found obsolete Chevy and they show no connectors or replacement parts to repair wiring. I have a call in to them but I am waiting for them to get back to me.
I can't find the "truck shop" you mention..
Projects..
440CID 2X4 Pontiac
Old 04-04-2013, 05:15 AM   #6
Vernski
Re: 66 cab wiring
Hey 66-PMD try www.classicparts.com they have different sections of the wiring harness. you only buy what you need or the whole harness...Vernski
Vernski is offline   Reply With Quote
Old 04-04-2013, 08:14 AM   #7
66-PMD-GMC
66-PMD-GMC's Avatar
Re: 66 cab wiring
Thanks Vernski,
The problem is that I have several, maybe close to a dozen different wiring harnesses that have nothing wrong with them other than a few broken connectors.
The pins come out of the connectors pretty easy and I have been able to make 3-4 complete wiring harnesses but that left me with a handful that just need to have connectors replaced.
I may have found a source and I will post it if I did.
As for the difference in wiring from idiot lights to gauges, other than the pig tail that plugs into the gauges, I see no difference in the wiring.
If I am wrong, I hope someone here will be able to tell me.
Projects..
440CID 2X4 Pontiac
Old 04-04-2013, 08:53 AM   #8
tincan1966
tincan1966's Avatar
Re: 66 cab wiring
If you can get your hands on an old Standard catalog- alot of the connector housings are still available thru local parts stores. You'll need to be armed with part numbers as most counter persons may not be familiar with how to look them up.
Also try www.repairconnector.com
tincan1966 is offline   Reply With Quote
Old 04-04-2013, 09:20 AM   #9
66-PMD-GMC
66-PMD-GMC's Avatar
Re: 66 cab wiring
I found American autowire. They sell connectors and terminals that are really close. I will need to replace both the male and female so they match but that is better than nothing. Thanks for the url...
Projects..
440CID 2X4 Pontiac
Old 04-04-2013, 12:46 PM   #10
Vernski
Re: 66 cab wiring
OK this link has terminals they may have what you need...Vernski
http://www.delcity.net/store/Termina...Fe1_Qgod9jwAZQ
Old 04-04-2013, 01:54 PM   #11
66-PMD-GMC
66-PMD-GMC's Avatar
Re: 66 cab wiring
Cool link!!!
Projects..
440CID 2X4 Pontiac
Old 04-04-2013, 02:11 PM   #12
Rich 5150 69
Rich 5150 69's Avatar
Re: 66 cab wiring
Here`s another link....http://www.repairconnector.com/
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
