almost scrap
![]() Join Date: Sep 2009
Swapping axles out of a 79 3/4 4x4 into a 72 1/2 4x4, (in regards to the rearend) and I've already noticed that one, maybe both, of the shock mounts need to be relocated, and am now wondering if the spring pad widths would be the same. If I have to relocate them as well it wont be the end of the world, just posting to see if anyone had any photo's or info on the actual 72 3/4 rearend. Thanks in advance for any info/tips.
Re: 1972 3/4 4x4 rear end questions
This is a recurring thread. Spring centers on 67-72 4x4 is 40.5", the same as a 73-87 one ton truck. 73-87 1/2 and 3/4 ton trucks have 42.5" spring centers, the same as 67-72 2x4 trucks.
So yes, you will have to move not only the shock mounts but the spring mounts. I preferred the 72 shock mounts on my Jimmy and used them on the '86 Suburban 9.5" 14 bolt that I swapped in. The SF 14 has 3 1/4" axle tubes so I reused the 86 spring pads.
![]() Join Date: May 2012
As long as you have to move the spring perches on the new axle pay attention to the angles. You can have the pinion angle dialed in on first pass. Don't just move the perches over without verifying the angeles. Plus my last 2cent tip is read all angle and distance yoke to yoke. Then reread angles after install. It's nice to have a baseline to work off of since you already got an assembly in the truck.
White K20 |
Vintage 4x4s
Unless you are after a ratio other than 4.10 or 4.56, I'm curious why you are putting in a heavier, weaker, less convenient to work on (no 3rd member), and less ground clearance axle? Also, being a 72, you can still buy brake drums and shoes for it. You could convert your HO 52 to disc brakes with probably the same amount of work for 300 or so FYI.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
I am pondering the same swap as well. If I could find some reasonably priced bearings for my 72 HO52 I would just rebuild it. While I had it out I would drop in a detroit and put in some 14 bolt axles
#6 | |
almost scrap
#7 | ||
almost scrap
almost scrap
Vintage, I just realized my mistake. I'm swapping the axles into a 72 1/2, not 3/4. My apologies.
What size tire do you plan to run? What about transmission? While the HO52 is a neat axle, the 14 bolt will be cheaper to swap in as well as getting a locker for if that's what you want.
Why not swap in the front axle from whatever your donor was? That way ratios are the same and no money spent. Especially $700! 10 bolt is as strong as the Dana 44 for the most part.
#10 | |
almost scrap
almost scrap
In an effort to help anyone with looking for good info, I found thread today.
http://67-72chevytrucks.com/vboard/s...d.php?t=536119 |
#12 | |||
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 01-14-2015 at 12:29 PM. |
#13 |
[QUOTE=Vintage Windmills;7003196]Ive heard that before but I got new bearings from rock auto, all timkens, for what I thought was a pretty good price. I think it was 100 or so. Can look at receipts when I get home.
I would appreciate some part numbers. Thanks |
#14 |
almost scrap
http://www.showmetheparts.com/timken/
not sure on the price but you can go here and find the correct part numbers. |
#15 |
The front is just a bolt in. And the rear mods are not that difficult or expensive. I'd continue on the path you are on as a good strength improvement for low cost.
I don't wheel my Jimmy hardcore, but the 35's were hell on 12 bolts. Actually 2 broke with stock tires on it. One in a freak backfire as my dad was letting the clutch out. I wish I had upgraded years ago instead of building and rebuilding 12 bolts...
#16 |
Thanks for the Timken site. I was able to get the bearing numbers and as usual the tapered pinion bearing for load bolt style 3rd is the killer at $255
Here is the list in case anyone is looking in the future Differential bearings 388A Diff pilot bearing M5205EL Differential pinion bearing 55197-90030 Pinion Seal 411330N The kit at Rock Auto is $481 plus shipping and looks to only add the pinion nut One thing on the Timken site is that they mentioned 2 pilot bearings are needed, I would think only 1 is required but anyone know for sure? |
#17 |
Please let me know where you found this price on the bearings, RA is the cheapest I could find but like I posted above the kit is $481. I could get a 2010 14 bolt with factory disks for $250 around here and a rebuild kit for $152 and still be into it less than a rebuild kit alone on the Eaton. Thanks |
#18 |
Vintage 4x4s
I was referring to the hub bearing sets. I haven't had one yet that needed pinion or differential bearings fortunately. I wasn't aware the pinion bearings were that ridiculous. Luckily, I have a couple spare 3rd members with good bearings. I would think you could find a 3rd member for about $150 that is ready to run?
Front D44 and rear HO52 part numbers. Sorry I don't have them separated here but Rock auto will sort it out if you go to the website. TIMKEN 388A Wheel Bearing $ 20.79 $ 0.00 2 $ 41.58 TIMKEN SET45Wheel Bearing $ 8.99 $ 0.00 2 $ 17.98 TIMKEN 362A Wheel Bearing $ 8.68 $ 0.00 2 $ 17.36 TIMKEN 382 Wheel Bearing $ 11.59 $ 0.00 2 $ 23.18 TIMKEN 368S Wheel Bearing $ 20.79 $ 0.00 2 $ 41.58 TIMKEN 368A Wheel Bearing $ 14.90 $ 0.00 2 $ 29.80 TIMKEN 362 Wheel Bearing $ 11.25 $ 0.00 2 $ 22.50 VICTOR REINZ 49435 Wheel Seal Wholesaler Closeout -- 30 Day Warranty $ 5.09 $ 0.00 2 $ 10.18 Here are some pics and part numbers for the wheel bearings. Also one of my finished disk conversion for inspiration.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 01-15-2015 at 12:02 AM. |
#19 |
Yeah the wheel bearings are fairly cheap, got my Timken sets and seals from autozone for $90 delivered.
HO52/72 thirds have pretty much dried up on the west coast when scrap prices went up, I can still find the occasional non load bolt 4.56 third for $150 or so but the bearings for that one are even more expensive, the 4.10 load style are in high demand so pretty hard to find and expensive these days. Dont get me wrong I love the Eaton but if I ever did trash something in mine it would be near impossible to get another third or axles while on the road. Im always looking for spares but not willing to pay $400 or more for some. |
#20 |
almost scrap
#21 | |
Vintage 4x4s
Thanks!
