Old 07-18-2015, 02:07 PM   #1
Wallee
1966 c60 wheel cylinder problems
Having a hard time sourcing new wheel cylinders and the ones I have found are high(100+). Has anyone ever had success rebuilding wheel cylinders? Rebuild kit is 8$
Wallee is offline   Reply With Quote
Old 07-18-2015, 03:05 PM   #2
Figuarus
Figuarus's Avatar
Re: 1966 c60 wheel cylinder problems
i've rebuilt wheel cylinders before. It's pretty easy.
make sure you find a centrifugal hone, some brake fluid, and the kit.
If you can, hot tank, or wire wheel the crap off the cylinder and if possible let sit in some vinegar overnight.
put some WD-40 or paint them when they come out of the vinegar as they may flash rust.
Hone the bore, clean the bleeder passage and reassemble.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 07-18-2015, 05:17 PM   #3
1976gmc20
We used to do it all the time back in the old days at the service station
Never had one come back that I recall.
I never even pulled them off; just cleaned everything up and honed them in place with a spring loaded hone chucked into an electric drill. Just make sure the cups are installed with the hollow side towards the brake fluid (inside).
You probably want to put in new rear axle seals while you have the hub apart to get at the brakes.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 07-18-2015, 06:49 PM   #4
Jurassic-1
Jurassic-1's Avatar
I have done a bunch. As stated in earlier posts a small hone and brake fluid is needed. run it in a few times and it should have about a 45degree pattern. Look for rust pitting. If it has pitting it may need replacing. Napa had wheel cylinders for $15-18.
Jurassic-1 is offline   Reply With Quote
Old 07-19-2015, 02:13 AM   #5
Wallee
Napa couldn't hardly find any for me and when they did finally they wanted 129$ apiece and I need 4 lol. Where can I get a hone like you guys are suggesting?
Old 07-19-2015, 10:52 AM   #6
1976gmc20
Ask for "brake cylinder hone" at your local parts store.
http://www.autozone.com/test-scan-an...-cylinder-hone
I always just used the ones that the shop already had
Old 07-19-2015, 03:23 PM   #7
BOE
they are about $20 in the Denver area at most auto parts stores. LMC has them for about the same or all four for $69.95. plus shipping of course.
BOE is offline   Reply With Quote
Old 07-20-2015, 01:02 AM   #8
Captainfab
60-66 Nut
Just to clarify, the OP is looking for wheel cylinders for a C60 not a C10. There is a big difference.
I would say that rebuilding the wheel cylinders you have is going to be the most economical way to go.
Old 07-20-2015, 10:53 AM   #9
1976gmc20
Yeah, a entire C10 wheel cylinder could probably pass through the bore of a C60 wheel cylinder.
Old 07-20-2015, 12:29 PM   #10
VictoriaHardware
VictoriaHardware's Avatar
I wish you the best of luck, but I'd be surprised if honing will clean the bores up enough. They are likely deeply pitted. Another option instead of new ones is to have your old ones sleeved. White Post Restorations is one such place that does this in brass. However, if you didn't like the cost of new ones, you won't like sleeving either. The advantage of sleeving over new cylinders is that you won't have the same problem later down the road. So if the C60 is a keeper, you may be better off in the long run. White Post did all of the wheel, master, and slave cylinders on my C80. Expensive but worth it.
VictoriaHardware is offline   Reply With Quote
Old 07-21-2015, 12:17 AM   #11
oakstcustomz
oakstcustomz's Avatar
Try these guys out
http://www.santarosabrakeservice.com I have had tons of luck where others have failed!! Might even have these in stock!! Been around for years and was going to use them when a customer had a c60 but upgraded the frame and drivetrain
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
