Old 11-07-2015, 02:20 PM   #1
LeesTruk
Air filter box dilema
Well, I modified my battery tray so that I could mount my air box. Only problem is, it's about 3" away from the rubber snorkel tube
Does anyone know if GM made different length rubber tubes for various vehicles? Or, does anyone have an idea for something else to joint the air box and plastic snorkel? Thanks
Lee
LeesTruk is offline   Reply With Quote
Old 11-07-2015, 05:08 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Air filter box dilema
You can buy the plastic tube at O Reilly's auto.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-07-2015, 07:50 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Spectre sells the stuff as well (that might be who oreilly sells) which you can replace the whole thing. I'd probably just grab a $2 piece of corrugated plastic downspout/water barrel tubing if you just wanna extend the little area.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-08-2015, 05:02 AM   #4
LeesTruk
Thanks, gents. One of the problems is the size of tubing required. GM uses a 3.75" orifice, and most flexible tubings are either 3", 3.5", or 4". Wanting to keep the aesthetics on a "factory" look, I really don't want to use an aftermarket CAI set-up. I've been searching the "web" and have stumbled onto something, though, that I may try. The rubber snorkel from a '99 Suburban 5.7 looks like it may do the trick. It has the 3.75" ID needed, and it's almost 9" in length, whereas my Tahoe snorkel is only 7". Guess I'll get one and see. I also came across a silicone turbo intake tube that has the needed ID, but it has a 4 ply thickness and may be too thick and stiff to conform to the required bends.
Later...
Lee
Old 11-08-2015, 07:35 PM   #5
Andy4639
Old member
Andy4639's Avatar
I don't know the exact measurements but all my parts are stock except the tube and it fit fine to the mass flow senor.
Old 11-09-2015, 09:39 AM   #6
MalibuSSwagon
mine reached....You may have to stretch it a bit.
MalibuSSwagon is offline   Reply With Quote
Old 11-09-2015, 09:56 AM   #7
LeesTruk
Eric, is your filter box mounted up against the inner fender panel, and what did you take your intake tube from? I tried to stretch my rubber snorkel but it still won't reach
Old 11-09-2015, 10:09 AM   #8
MalibuSSwagon
My whole intake is from a 2000 Silverado. The air box is up against the inner fender panel. I would suggest unbolting the air filter box, hooking up the tube to the maf, and then moving the filter box around til it fits the way you want it.
Old 11-13-2015, 05:33 PM   #9
LeesTruk
Eric, tried your suggestion. Thank you, sir. It WILL reach by stretching
Lee
Old 11-13-2015, 06:30 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Damn its almost like thats how something corrugated is engineered to work....pause...ok I'm being a dick.
Old 11-13-2015, 06:42 PM   #11
LeesTruk
Well, Dick, my only concern about pulling it so tight is that if, for whatever reason, the band clamp decides to loosen, that engineered corrugated tube might just want to return to its' natural relaxed state away from the MAF sensor
Old 11-14-2015, 08:31 AM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: Air filter box dilema
Originally Posted by LeesTruk View Post
Thanks, gents. Wanting to keep the aesthetics on a "factory" look,
Yea ok, factory 2000 look in a 67-72 truck!
Old 11-14-2015, 02:31 PM   #13
LeesTruk
Say what you will, sir, but it sorta "looks" factory to me, in my '80 C10
Old 11-14-2015, 09:24 PM   #14
Andy4639
Old member
Andy4639's Avatar
Sorry wasn't meaning it in a disrepectful way. I just assumed it was of the 67-72 era.
Old 11-14-2015, 09:35 PM   #15
LeesTruk
No apologies necessary, sir. I'm here to learn, just like most folk. I appreciate your pic's and ideas
