Removing 72 E-Brake handle...
Is there a trick to this? Or is this a cut off operation?
Go Pack Go!
Re: Removing 72 E-Brake handle...
There's 2 nuts on firewall (engine side) and 1 nut under dash. I think you need to remove a number of dash bolts in order to be able to flex the dash enough to get the assembly out because it still has the studs.
![]() Join Date: Jun 2005
Don't need to remove bolts it should be able to shift sideways enough to remove it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
I had a devil of a time taking mine out, I took out the three bolts on the drivers side of the dash and that gave me ample room to flex it out.
Going back in was almost as difficult. Ben
The handle is barb fit on the rod. Mine broke trying to remove it. Bought a replacement.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
I believe he was referring to removal of the pedal assembly, and I'm pretty sure the black plastic "T-handle"(that says brake release) is threaded.
Ben
I should have been more clear....was really asking about the black release handle, not the pedal assembly.
Just unscrew it, the release rod is threaded.
Thanks. Im guessing the PO must have glued it on as it was maybe lose? Thing will not budge. I will consult with mr. dremel.
He should be able to take care of it.
| Bookmarks |
