>>>where do i drill hole for diy vented gas cap<<<
CARB IS FLOODING AFTER REPLACING ALL FUEL LINES AND MECHANICAL FUEL PUMP
TANK HAS 2 LINES OUT AND VENT PUMP ONLY HAS 2 LINES IN (FROM TANK) AND OUT (TO CARB) BROTHER TEXTED ME TODAY SAYING CARB FLOODED BADLY - GAS EVERYWHERE TOLD HIM TO CRACK OPEN THE GAS CAP UNTIL I CAN GET OUT THERE TOMORROW MORNING I SEARCHED ON HERE AND FOUND ALLOT OF GUYS JUST DRILL A PINHOLE IN THE GAS CAP TO TRULY MAKE IT A VENTED GAS CAP BECAUSE THE STORE BOUGHT "VENTED GAS CAPS" DO NOT TRULY VENT BUT HOLD 3psi ! DOES ANYONE HAVE A PIC OR DIAGRAM SHOWING WHERE I AM SUPPOSED TO DRILL THE PINHOLE? THANKS GUYS I WILL CHECK BACK TOMORROW MORNING |
![]() Join Date: Mar 2003
Re: >>>where do i drill hole for diy vented gas cap<<<
If the carb is flooding, you more than likely have a sunk or stuck float. Randomly drilling holes in things isn't going to fix it, and get rid of the caps
![]() Join Date: Apr 2015
Not shure on the gas cap drilling ..but I would check the carb float bowl and check that the needle is seated properly and adjusted right..
I had a similar problem on my 67..
The cap installed by the PO was unable to vent adequate pressure, resulting in gas forcing itself into the carburetor and eventually into the crankcase. I used a NAPA cap (p/n: BK 7031220) to remedy this. It worked like a charm! No more contaminated oil or carburetor flooding. Hope this helps! |
@TurboThrift
YOU KNEW EXACTLY WHERE I WAS COMING FROM! FIRST STOP NAPA !! THANKS FOR THE PART NUMBER TOO! VERY HELPFUL POST - THANKS BRO |
Clavo106 & kwmech
THANKS FOR YOUR INPUT GOING TO CHECK CARB SPACER HEIGHT, CHOKE SETTING AND FLOAT SETTING AS WELL |
| Bookmarks |
