70 K10 blower motor
Anybody ever remove the bottom screw in less than 1/2 hour w/out taking inner fender off?
Re: 70 K10 blower motor
It's easy when you take the hood hinge loose and prop ithe hood up out of the way.
#3 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
BlahBlahBlah
Looks like a fun job, mine is starting to howl now and then. Add it to the list haha.
Hadnt thought of that saxart, but think I will wait till I have reason to take inner fender loose and put bottom screw back in...
![]() Join Date: Oct 2010
I have taken the inner fender loose and done this. It was my 2wd though. Looking at the hole in saxart's post you could drill a hole and plug with a rubber plug.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
