Rear shock bolt ripped out of frame
What’s my best bet at going about this ? ... I plan on redoing the whole suspension, brakes, everything as I have the truck down to a rolling frame right now. But the previous owner really... badly welded this on here and I got it off ... but I don’t see how I’d put another one in ... is there any good relocations for better shock placement, should I just bite the bullet and do a 4 link?
![]() Join Date: May 2015
Re: Rear shock bolt ripped out of frame
I would make a plate to cover up that mess...no big deal to fix that right
#3 | |
Relocated upper mounts can be done or the complete suspension change as you mentioned will also put the shocks in a different spot. More info from you about everything yields better options.
Plan is to have. Nice handling Street/strip truck
Decent power goals in mind with lots of money in suspension/brakes |
![]() Join Date: Mar 2003
If going back with welding I've seen these on Amazon (I think)
Not a bad idea
But I’d have to figure out a way to cut it out and fill it in with a new hole... I’d rather not just put a plate over it cause then it wouldn’t be even with the other side |
simple plate and one of the studs like KW shows will fix it.....doesnt have to match the other side
that small of a thickness difference wont affect anything
Alright maybe I’ll do that then
I assume you put it on the inside of the frame ? |
#9 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-01-2019 at 05:46 PM. |
My bad
I am changing out everything Most likely tubular a arms, coils, c notch, 9” in the back, etc etc |
here is a kit that works great to help save before broken frame or help firm up a repair .
these guys have good stuff . http://offroaddesign.com/catalog/RearShockBrace.htm
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#12 | |
Look @ Ride Tech, Hotchkis, & QA1 for suspension upgrades that are bolt-on swaps w/your existing crossmember & steering box up front. No Limit Engineering or Roadster Shop for revised & updated geometry bolt-in suspensions w/revised crossmembers w/R&P steering. Check them out & share your thoughts. We can help guide your decisions from there.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-01-2019 at 07:47 PM. |
#13 |
Alright thank you I will check them out and let you guys know
#14 | |
With lots of money in suspension and brakes, and since you have the truck down to a rolling frame, sound like ya answered your own question.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
| Bookmarks |
