Old 12-15-2019, 08:44 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Question???
Is this the right nut for 67-72 door panel screw's. The ones in the lower part of the door for the metal panel.
1/4"-20
https://www.grainger.com/product/487...g!109231851957!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-15-2019, 08:50 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Question???
That is the correct thread but the retaining clips look like they stick out farther. Don't know if that will interfere with the panel fitting up against the door or not.
LockDoc
Leon
Old 12-15-2019, 08:50 PM   #3
dzbowtie
dzbowtie's Avatar
Re: Question???
IIRC, those are correct. My door panels are the metal style and I have replaced a few of these over the years
dzbowtie is offline   Reply With Quote
Old 12-15-2019, 09:28 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Question???
Pack of 25 for $8.00 maybe worth finding out.
Old 12-15-2019, 09:38 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Question???
You ain't ordered those yet?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-15-2019, 11:43 PM   #6
dmjlambert
dmjlambert's Avatar
Re: Question???
The nuts on my doors are a different kind, they are square nuts with tabs and appear to be permanently attached in some way into the square holes in the door, I don't know if pressed or welded. I had one that was rusted and broke loose, so I replace it with one of those cage nuts you show above, that I got at Ace Hardware. It works fine.
Last edited by dmjlambert; 12-15-2019 at 11:52 PM. Reason: changed word wings to tabs, it is a better description
dmjlambert is offline   Reply With Quote
Old 12-16-2019, 10:28 AM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Question???
Thanks that's what I'm hoping for as well. I had 2 of them break while getting the passenger side door panel off.
