![]() Join Date: Nov 2013
Gas tank filler tube
I put a Gas tank in my truck bed. Need to fill the hole. Cut the filler tube from the old gas tank. With a new rubber for the hole, a hose clamp and the tube, The rubber went on first then slipping the tube in putting the clamp on from the back and tightening it. Well another DIY done
Re: Gas tank filler tube
Seems pretty simple and cheap to do. Good idea.
How did you cut filler neck off tank. I wanted to do that but was afraid.
1968 c10 swb Stepside |
Did you block the tube hate to see anything get in there specially gas
Seems you have found the Only good use for an old fuel tank!
Might be able to cut it off with a large pipe cutter or a muffler cutter. |
Senior Moment
![]() Join Date: Mar 2002
Nothing New. I did this years ago. Good idea
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
The tube came off my truck when I put a new tank in the bed. No gas was in the tank when I cut the tube I air out the tank about three weeks. Cut it with a saws all. Going to blank off the tube at the top from the inside welded
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
| Bookmarks |
