Roadtrip!
Was being a GMC an option???
Odd...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: Was being a GMC an option???
General Motors Corporation?
Garage Man's Companion? What's Z86, again?
![]() Join Date: Jan 2007
Give Me Chevy!
Project "C10 Fever" (68 factory black 396 swb) Project Faded Glory (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
It would be interesting to see the rest of the vehicle...
#5 | |
![]() Join Date: Feb 2002
Model Chevrolet ![]() Looking at the VIN on the SPID, it's a C/50 with a 174'' wheelbase.
Get More Cash?
I don't see it as GMC since there are periods typed between each letter, I figure, to distinguish from GMC
#7 | |
![]() Join Date: Feb 2000
Z88 is the RPO for GMC Conversion
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Jan 2002
Is that a 174" wheel base.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
Yes. It's also "incomplete vehicle certification label", so was possibly going to be a bus or something like that.
#13 |
Roadtrip!
Can you expand on that?
This one had a fuel tank on back.
#14 | |
This is a medium duty cab & chassis and the 174" wheelbase is just a normal WB offered. It's only 15" longer than a 157" WB C/30
#15 |
Based on the model number it was just a cab/chassis- an upfitter would put on a dump bed or tanker on the back.
CE56803= C = conventional cab (S for school bus chassis, T for tilt cab) E = V8 5= C50 series 68= 108" cab to axle (this would be '18' if it was a Chevy) 03= cab except full air brakes
#16 |
Sure.
The model code is not "nameplate" specific; ie C10703 or K30943 doesn't tell the operator what brand vehicle it is. RPO Z88 is the "nameplate conversion" option that specifies that everybody needs to put GMC emblems on the truck. Similarly, there is a "Chevrolet nameplate conversion" option (I wanna say X88) and, in later years, a Cadillac RPO (aka Z75). All these trucks were run down the same line. K
#17 |
All about them Ks
![]() Join Date: Jun 2014
Awesome info Keith. Learn something new every day.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
#18 |
Roadtrip!
Thanks keith.
#19 |
Ok, so if I understood that right, both Chevy and GMC were options since both brands were identified as one truck line. It was more like a selection than an option. You HAD TO select one or the other. There was no going without it like with an option. Like paint color, you get choices but paint is not an option, it's a selection
#20 |
You could think of it that way, but they were called "options" (ie, RPOs) nonetheless.
In some cases if you didn't choose there was a default option. For example, if you didn't choose a color then you got the tan exterior picked for you. Maybe powertrain is a better example. There was a base engine, a base transmission, and a base rear axle. If you didn't choose anything then you got the base powertrain combination, but each of those was still defined by an RPO. Additionally - everything had to balance out when the Engineering Specifications group ran their "cross balance" report to make sure all the combinations were covered. So for every option there had to be a contrasting "negative option" to balance it out, enabling Specs to run their computer generated report and ensure there was a part number created to cover all the proliferation of option combinations. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-27-2022 at 09:37 AM. |
#21 | |
I guess. (lol)
#22 |
I recall seeing that one could buy a vehicle in primer. That was in '71. Not sure why someone would do that, since it would be really difficult to get everything painted after the vehicle was assembled.
#23 | |
Mom says I've always been curious
#24 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Really good info Keith, learned something new!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#25 | |
Back in the day - the mass production body work on a Corvette was so bad that you could not order a black car from the factory. You could, then, get a primered car and have the prep work done and painted black after the fact. K
| Bookmarks |
