window regulator replacement rollers
Anyone know where to find replacement window regulator rollers for my 1975 K10
thanks |
Re: window regulator replacement rollers
I pulled mine off another window regulator
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
I have used some universal ones from the parts store help section.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
chevy truck fan
I recently "revitalized my mechanisms... i need to replace mine as well. how would you go about replacing them once you have suitable replacements?
Got new rollers from AMD
ground the rivet head off took the roller to be removed stuck it over a large socket. used a punch and removed. Put the new roller in place. Use a sharp chisel and cut and X on the peg Put the mechanism roller in one side of the vice. took a pointy fender bolt in the other side. Put the bolt point in one part of the X off centered Tightened the vice. Move it to the other side of the X. This flared both sides then I banged it flat . took about 10 minutes to do one after I figured it out |
Haven’t done my square but just did my 68 so I’m not sure if they are the same . Ground the peen’d part of the rivet removed the roller . Used a socket to back up the new rivet and roller , used a punch and peening hammer to flatten the peen .
Nice work. The square body one's don't have a dimple on the back. They are flat so you have to cut them so you can roll them over
So they are cross peened.
chevy truck fan
hhmmmm... interesting, pretty cool. nice job to both of you!! and thanks for the write up!!
| Bookmarks |
