Old 12-09-2024, 02:51 PM   #1
pjmoreland
pjmoreland's Avatar
NP205/Transmission Adapter Measurements Request
I will be installing an NV4500 transmission in my K10, and my plan is to fabricate an adapter bracket for it to allow it to bolt to the stock transmission crossmember mounts. Do any of you by chance have a stock SM465 or TH350 NP205-to-transmission adapter available for taking a couple of measurements for me, please? I'm looking for the following two dimensions:
A) The vertical distance from the crossmember mounting surface to the centerline of the transmission output shaft
B) The horizontal distance from the transfer case attachment surface to the centerline of the crossmember mount bolts
Thank you.
pjmoreland is offline   Reply With Quote
