Big Notch / Step Notch - Which One?
Research hasnt drummed up much for me here - I am looking at bagging my truck and want to see what people have done for the rear in a DIY setup.
I am interested in running the Evolve notch (https://www.avsontheweb.com/evolve-63-72-c10-notch-set/) because its already prefabbed, and just needs welded for install, and also is 'longer' (which I would think would help with strength and of course looks) but am curious if it truly has advantage over the normal step notch such as the one Switch sells (https://switchsuspension.com/gm-c-10...piece-c-notch/). I also plan on running the Firestone sleeve style bags, as Ive heard they ride well in these trucks. Any advisement on the placement? Top of axle? Front of axle? Running a watts link, so rear is not an option.
C10 Club Virginia President Toano VA "Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
#2 | |
![]() Join Date: Dec 1999
Re: Big Notch / Step Notch - Which One?
Have not done a full bagged vehicle before. If I did I would do bags on the trailing arms in front of axle like the stock coil springs. Would think that placement gives more adjustment of height JMHO
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#3 | |
I would run the bag in the factory coil spot, but I dont want to run a large drop block to achieve frame laying. I may be swapping to 4 link after all is said and done. I have a Porterbuilt front sentup that will allow me to lay frame granted I set the rear up to do so as well.
#4 | |
They need to be relocated elsewhere on the T/A w/a revised upper mount or moved to the rear end housing if the plan is to plant the frame rails on the ground.
| Bookmarks |
| Tags |
| air ride, evolve, firestone, notch, switch |
