Old 04-21-2007, 11:45 PM   #26
FLEET72
FLEET72's Avatar
Re: Gear Numbers
Originally Posted by AuggieStyle View Post
Is there a formula to help decipher the code on the rear end to help find the gear ratio?
How does 14:43=3.07?
43 / 14 = 3.0714286 (3.07)
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 04-22-2007, 03:45 PM   #27
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Well seeing that I still cant get the bolt out to change axles, and I broke a $12 bolt removal tool in the hole I will be looking for the whole thing. wheels and all. Now the question s do I want to buy it new or grab one from the local pick a part. Anyone is southern cali now of a spot?
VDOG is offline   Reply With Quote
Old 04-22-2007, 03:48 PM   #28
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Also where do I add the new gear oil in the rear end?
Old 04-25-2007, 05:55 PM   #29
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Really guys, where do I put the gear oil in? Did not see any place th pour oil in.
Old 04-25-2007, 06:22 PM   #30
Mt Man Chad
Mt Man Chad's Avatar
Re: Gear Numbers
The Formula = Divide the big number by the small one and that's the gear ratio!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-25-2007, 09:34 PM   #31
retro69
Re: Gear Numbers
Hello all! I have a 1969 and I have not had a chance to check the rearend yet, but I read somewhere that this year truck was factory gear ratio of 3.73. with optional 3.08 or 4.11??? So does your glove box tag have an option for that gear ratio special ordered?
1969 C10 Long Wheel Base
1985 Monte Carlo SS(Snake Charmer)
retro69 is offline   Reply With Quote
Old 04-26-2007, 09:57 AM   #32
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Gear Numbers
On the front or Yolk side of the axle there will be a squared hole pipe plug, use a ratchet to remove it. On level ground fill untill oil starts to come out the hole.
sneakysnake is offline   Reply With Quote
Old 04-26-2007, 11:10 AM   #33
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gear Numbers
Another way to tell the ratio of the rear gears is by the code stamped on the passenger side tube of the rear end housing. The first picture shows the area of the housing where the code is stamped and the second picture is of the code number itself. When You have the code just use the first two or three letters ('67-'69 have two letters & '70-'72 have three) and look it up here in the axle codes section.
http://www.americanclassic.com/paint.htm
The letters TDE on this one tells me it is a 307:1 - 1/2 ton assembly
LockDoc
Leon
Old 04-26-2007, 01:03 PM   #34
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Gear Numbers
What you read, was misleading.
True, the BASE MODEL truck, came with a 3.73... however, that does not mean that the standard gear will alwaysbe 3.73.
There were trannys that would come with a 4.11, and other trannys that would get you 3.07 gears. (3.08 was a car gear)
Yes, if there is an optional gearset, then it would be listed, but, that doesn't mean you have 3.73's though.
What engine, and tranny did your 69 come with originally? (if no engine option listed, then it was a 307 for a CE truck, and a 250 for a CS truck)
Old 04-26-2007, 01:54 PM   #35
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Will an 81 chevy rearend fit my 69? Found one for 150.00 so I thought I'd ask.
