12-09-2009, 07:22 PM | #26 |
425hp409
Re: Radiator Shroud
If I was putting an electric fan in the shroud, I would put it at the rear edge fo the shroud for optimum performance.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
12-09-2009, 07:59 PM | #27 |
Re: Radiator Shroud
12-09-2009, 08:10 PM | #28 |
Re: Radiator Shroud
I"m confused-------why do you put a V8 in the 6 cyl mountholes? are 6 cyl and V8 mounts different sizes ?
12-09-2009, 08:42 PM | #29 |
Big Red - Now its a SWB!
Re: Radiator Shroud
The v6 and I6 motor stands sit in the rear mount holes, while the v8 stands sit in the front set of holes. My small block is in the 6 cyl mount location. This is because when I swapped out the 351 V6 I didn't want to move the transmission, lengthen the driveshaft, etc. I suspect that the others prob swapped out I6's since they are more common. To solve my fan distance issue I am in the process of mounting up a 16" e fan/shroud combo out of summit with a thermostat.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 12-09-2009 at 08:46 PM. |
12-09-2009, 09:33 PM | #30 | ||
Re: Radiator Shroud
Tight, but it will fit, but my dizzy has the coil in the cap
12-10-2009, 01:25 AM | #31 |
Re: Radiator Shroud
ok, I used shorted brackets which brought it back a bit. The brackets hold it very securely, however when I put 3/8" of sponge-rubber weatherstrip around the outside edge, I thought I was going to need a huge press to get it in! Finally with a bit of clamping I got it to set perfectly. It would be a struggle to get it out... so hopefully this will keep temps correct. Shouldn't be to bad if I need to go back to the original, best of all - NO HOLES IN MY SHROUD!!
I fired it up she's definitely a sucker! Hard to tell how loud it will be in the truck, a little loud now but it's very quiet around here. Any idea what the cfm rating on this fan is?
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
12-10-2009, 01:48 AM | #32 | |
Re: Radiator Shroud
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-10-2009 at 01:53 AM. |
12-10-2009, 02:11 AM | #33 |
Re: Radiator Shroud
80 amps!? I've heard 30 and 20 but 80 seems a bit much. I've only researched the relays briefly, but will be getting something. I need to look into hooking it up to my trinary switch as well.
what's the rating on your relay?
12-10-2009, 01:20 PM | #34 |
Re: Radiator Shroud
You may be right, just thought I read that somewhere. Anyway, I searched Tyco site for part number-VF4-1511-Z01 but couldn't find an exact match. This is the relay M&H supplied with my harness for the electric fan application
12-10-2009, 02:21 PM | #35 |
Re: Radiator Shroud
are you using a radiator probe or a sensor in your head?
12-10-2009, 03:28 PM | #36 |
Re: Radiator Shroud
I have the factory senser in the intake manifold, but you could weld in a 1/2" NPT bong in the radiator. Didn't like shoving the probe into the fins of the rad
12-10-2009, 05:13 PM | #37 |
Re: Radiator Shroud
Mine was a stock fan set up, sorry but can't help you with the electric fan set up, but looking at it, I think they put them in a bit because that is the stronger part of the shroud
12-10-2009, 05:49 PM | #38 |
Re: Radiator Shroud
Sorry, been off the site for a few days. I have a stock fan, no clutch on my setup as asked previously. I have not gone the electric fan route. I know more folks than not use them but just my preference. The stands I used, all I did was take them off the 6 cyl. and put them on the 8. They bolted right up to the motor. Im running the old points style distributor and yes it is tight but manageable. Hope this answers any questions about my setup..
12-10-2009, 06:31 PM | #39 |
Re: Radiator Shroud
Sorry Steve,
Didn't mean to attempt a hostile take-over of the thread!
12-10-2009, 09:22 PM | #40 |
Re: Radiator Shroud
Hi tony thanks for the update. I may go back to the clutch fan now that I learned from the guys on this site on how the fan is supose to fit and what kind of shroud to use. thank you.
