Old 07-08-2010, 12:12 AM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Lifting engine
I need to change the Oil pan gasket on my 350, I everyone I've talked to said I'll need to lift the engine a few inches. So don't have a hoist, but I got a front end loader on my tractor, anyway where and how do I connect the chains to the motor? Thanks Yall!
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 07-08-2010, 12:19 AM   #2
jayman68
Fun Stuff
jayman68's Avatar
Re: Lifting engine
Sometimes there are lifting rings mounted with the intake bolts. Or you could just put a bolt thru the end of the chain into the front of the heads.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 07-08-2010, 12:20 AM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
Re: Lifting engine
Can you jack it up? Maybe try to drop the pan with the crank spun up in the front first?
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 07-08-2010, 12:25 AM   #4
1968CHEVYC10
Re: Lifting engine
Is this what you were talking about? there is one just like it on the opposite corner of the intake manifold.
Old 07-08-2010, 12:28 AM   #5
1968CHEVYC10
Re: Lifting engine
I've thought about it, but it seems like it would be more stable pulling from the top, and also easier to keep there while I work.
Old 07-08-2010, 12:34 AM   #6
jayman68
Fun Stuff
jayman68's Avatar
Re: Lifting engine
Yes, that is the lifting eye. You can move the one from the back up to the front, across from the other if there is room. Then just disconnect the engine mounts and lift.
edit: just be carefull not to lift too far and break wires and stuff.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 07-08-2010, 12:36 AM   #7
1968CHEVYC10
Re: Lifting engine
Is that so I wouldn't need to mess with the tranny xmember? Or do I need to undo the tranny mounts too? thanks for your help!
Old 07-08-2010, 12:41 AM   #8
jayman68
Fun Stuff
jayman68's Avatar
Re: Lifting engine
You shouldn't need to disconnect the tranny, unless the engine will not go high enough.
Jay
68 C10(project)
88 Honda Accord(DD)
Old 07-08-2010, 07:30 AM   #9
69c10step
69c10step's Avatar
Re: Lifting engine
When I changed mine (IIRC), I just unbolted the motor mounts, used a floor jack to raise the engine up a couple of inches and then slid a 2x4 block in between the mounts and the motor. Worked well - just another way of doing it I guess.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 07-08-2010, 02:08 PM   #10
1968CHEVYC10
Re: Lifting engine
Did you have to mess with the rad hoses? I just changed my coolant and don't really feel like changin it again.
Old 07-08-2010, 02:12 PM   #11
69c10step
69c10step's Avatar
Re: Lifting engine
I don't think that I did (it was about 3 years ago). I didn't have a ton of room to work with, but enough to wiggle the pan off.
Old 07-09-2010, 03:18 AM   #12
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
Re: Lifting engine
exactly!
I had a friend jack up both the oil pan and transmission pan at the same time (with 2x4s between jack and pans) then slide pieces of 2x4 in motor mount spot . He had to loosen tranny mount bolts and of course motor mounts. Hoses won't be disturbed with the 2-3' inches of lift.
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 07-09-2010, 09:13 AM   #13
Alex Hayley
Re: Lifting engine
Don't forget to disconnect the throttle cable.
Alex Hayley is offline   Reply With Quote
Old 07-09-2010, 09:18 AM   #14
69c10step
69c10step's Avatar
Re: Lifting engine
...and make sure the distributer doesn't smash against the firewall
Old 07-09-2010, 09:57 AM   #15
mrein3
mrein3's Avatar
Re: Lifting engine
Originally Posted by beebster View Post
exactly!
I think this is what the GM service manual recommends. And is how I've done these jobs.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
