Old 03-21-2013, 01:11 AM   #1
Mister-B
Where to buy bench seat hog rings and pliers?
When I ordered my seat cover, it didn't dawn on me that I'd need hog rings and pliers. They sell both at Brothers for a good price, but at this point shipping would cost more than the kit, and it would be a while before it gets here.
I've checked Home Depot, but theirs is for chain linked fences. Checked Harbor Freight, but they only carry the pliers.
Is there a brick and mortar store you know of that carries these?
Mister-B is offline   Reply With Quote
Old 03-21-2013, 01:17 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Where to buy bench seat hog rings and pliers?
My local tractor supply carries them. I don't know if you have any kind of a farm store near you or not. If you do give them a call.
LockDoc
Leon
Old 03-21-2013, 01:19 AM   #3
JOJABOY
O'Reilly, Autozone
JOJABOY is offline   Reply With Quote
Old 03-21-2013, 01:22 AM   #4
Mister-B
LockDoc
Yeah, we have IFA, Cal Ranch, etc. Wont that just be chain link fencing stuff, vs interior rings?
That's a great idea though. Hadn't thought of that. Is there just a standard type ring I can ask them if they have?
Old 03-21-2013, 01:39 AM   #5
LockDoc
LockDoc's Avatar
All I know them by is hog rings. What is different about the fencing rings?
LockDoc
Leon
Old 03-21-2013, 01:50 AM   #6
buckskins4ever
buckskins4ever's Avatar
Call an upholstery place and ask if they have an extra set and some rings they might sell ya.....or at least tell you where to get the right ones.
buckskins4ever is offline   Reply With Quote
Old 03-21-2013, 01:51 AM   #7
Mister-B
LockDoc
I've never used hog rings of any kind, so I'm trying to figure this out. I assumed when Home Depot said they are for fencing, that they must be different than interior rings, but maybe not.
This is a pic of the ones from Home Depot. Will that work?
Old 03-21-2013, 01:53 AM   #8
SS Tim
SS Tim's Avatar
Fence rings are larger and heavier wire. Automotive rings tend to be sharper as well. Try finding a on-line auto trim supplier. Good pliers are a must, cheap pliers are an absolute pita. If you want, email any item specific links for on-line or ebay and I'll take a look at them.
SS Tim is offline   Reply With Quote
Old 03-21-2013, 01:54 AM   #9
LockDoc
LockDoc's Avatar
Yep.
Leon
Old 03-21-2013, 01:55 AM   #10
67swb72klb
67swb72klb's Avatar
try an auto uphostry supply or any of the larger craft stores (joann fabrics)
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-21-2013, 02:03 AM   #11
Mister-B
Harbor freight has these pliers
http://www.harborfreight.com/straigh...iers-3102.html
Would these rings work?
http://www.homedepot.com/p/Prime-Lin...6#.UUqim-69KSN
Old 03-21-2013, 02:08 AM   #12
SS Tim
SS Tim's Avatar
The Home Depot fence rings will not even fit in my automotive ring pliers. They are a heavier gauge wire than the automotive rings but I still ended up at a fence supply for rings that were bigger and a heavier wire (about 50%) for my dog anti-dig panels.
For automotive work you want a quality sharp ring that will close fairly easy with the ends passing not butting as it goes round.
Old 03-21-2013, 02:18 AM   #13
Mister-B
They have different sizes at Home Depot. That last one I posted a link to is a small size 1. Would those not fit the harbor freight pliers?
Old 03-21-2013, 02:37 AM   #14
SS Tim
SS Tim's Avatar
Actually the rings might work out well for your application. The reason I say this is your cover is a basic bag and attached at the edge. If it were say a styled cover like a bucket that uses listing wires on the seating and back faces to pull the cover into the foam shape and hog-ringed to molded in wire forms. Then I would want a small sharp ring.
The pliers might work. They may be too big at the tip end. The spring is a big help too. I'd buy some rings and run by HF to try a pair if they stock them. If they close the ring down to a round pencil size you are good to go. However the tips might need grinding, back toward the cups, to get into tight spots. Most pro pliers have a real high taper to make tips as small as possible. So forget any of the cast metal type pliers you see with a 1/8th or so flat ledge around the tip cups.
Old 03-21-2013, 02:45 AM   #15
Mister-B
Thanks for your help!
Old 03-21-2013, 02:58 AM   #16
SS Tim
SS Tim's Avatar
How did we end up without a Husky picture in a Mister-B thread?
Here are two of my spell check/editor/research assistants tonight.
Old 03-21-2013, 03:02 AM   #17
Mint68
Mint68's Avatar
A budy of mine needed some and went in to an upholstery shop and the guy gave him a bag for free. I would check an upholstery shop first for supplies, may not have pliers, but they should have plenty of the rings.
Mint68 is offline   Reply With Quote
Old 03-21-2013, 03:08 AM   #18
SS Tim
SS Tim's Avatar
Did a little checking and found some KD pliers at amazon. The first link is for 3702 straight handle pliers and they also have a 3704 bent handle plus 3702 a set of both. Straight or bent is a matter of preference and working space (like under a progressive cover installation). Straight would be my default, if you need the excuse the set will cover about everything.
KD Tools 3703 Straight Hog Ring Pliers -... KD Tools 3703 Straight Hog Ring Pliers -...
KD Tools 3702 2 Piece Hog Ring Plier Set -... KD Tools 3702 2 Piece Hog Ring Plier Set -...
Old 03-21-2013, 03:12 AM   #19
Mister-B
Well, seeing as my boy is in my avatar, you'll never escape a post from me without a husky Lmao
Great looking dogs, by the way
Old 03-21-2013, 08:01 AM   #20
Rick212
Rick212's Avatar
Where did you get your seat covers? Did you also get new foam? I am in need of a complete overhaul of my seats and am about to give it a go.
Thanks...Rick
'72 Blazer 4x4
Rick212 is offline   Reply With Quote
Old 03-21-2013, 09:58 AM   #21
Mister-B
Thanks...Rick
'72 Blazer 4x4
I got it from Brothers. It was around $150 for a vinyl cover that's supposed to look stock
My foam seems fine, but when I start replacing the cover, if it needs foam or springs, I'll go to the junk yard for that
Old 03-21-2013, 11:10 AM   #22
I just go to my upholstery guy and he'll get me anything I need. I've never had him get my tools but I'm sure he'd get them
Old 03-21-2013, 11:16 AM   #23
b.eddy's72
b.eddy's72's Avatar
Larry Dennis Company in Fort Worth Texas has it all. It is a textile compnay and they ship all over. I used to work there almost 20 years ago and still buy from them when I need something.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-21-2013, 02:34 PM   #24
Mister-B
Brothers really pulled through, and did a nice touch with my order. Unbeknownst to me, they put a pack of hog rings and some pliers in the box with my seat covers that just got delivered!
Old 03-21-2013, 04:32 PM   #25
JOJABOY
Mark and the guys over in Corona do a great job. You can't ask for a higher quality part or better customer service.
