Re: What did you do to your truck today? Chapter II
Finaly got Katy an alignment. Its been almost 2 years since i bagged it. One thing or another always seemed to come up, but its done. It was off alot(wore through a set of fronts in 1000 miles). Drives awesome now!!
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018 |
Nice truck.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
![]() Join Date: Nov 2007
I went to see about mounting some front turn signals. Opened the hood and spent the next 15 minutes killing wasps. They made a nest above that tiny hole in the hood where it contacts the hood bumpers. Why the F*%k do wasps love these old trucks so much? I just had the hood open the other day and there were none.
Got the wasp population down and tried to work on wiring taillights. Battery almost dead and quickly got tired of laying on concrete outdoors in the 100+ temps. Eff it, I'm going back inside.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#4 | |
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
![]() Join Date: Nov 2013
I figured out the easy way for now to get the back tailgate level. The bed leaned down on the driver side. I removed the two bolts from the left/back of the bed. I jacked the bed up by the rear rail. I made two shims, slip them in & bolted them back up. Game out good. Next going to get the exhaust even .
Webfoot said, ((((Why the F*%k do wasps love these old trucks so much?)))) Who doesn't love them....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
It rained all day today so all I have done is get hood hinge number 2 out of the ERR tank and into Evaporust and I primed hood hinge number 1 with NAPA Rust Treatment.
Once the hood hinges are done all that I will have left to clean up will be the charcoal canister bracket. |
got the leaking oil pan off clean and painted of course nobody has a new gasket in stock so hopefully tomorrow . did find a 5/16 x 1 bolt in the bottom of the pan cant find any missing anywhere it was running good other than the oil leak . all I can think is someone had the pan off before and it found its way in then but ill check for a sixth time tomorrow before I put it back together
Wasps are just part of the fun.......
![]() I really like that dash cover ! . I hope the sun doesn't beat it up too fast . RE hood hinge in Evaporust : did you de grease it before soaking ? .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#10 | |
Ya know that bolt you found could be 1 of the 3 that hold the top timing chain gear on, hope you don`t have the cam gear coming loose. something to thihnk about. Wildcard |
I did get the gaskets and got the pan back on now I really need to get the engine cleaned and painted . the only problem I had was the new gaskets for the front timing cover didn't have holes for the bolts so I had to use silicone gasket maker . but it looks like im going to have to pull the timing cover I might have a gear coming loose . oh well I think it looks better when the covers are painted off the engine anyway . greased everything while I was under there everything looks good and tight .
Changed the air horn on my barb due to a crack and set the timing to 10* btc. Drove it around town. Been a good day with goldilocks.
![]() Join Date: Jun 2015
Started tearing things apart.
#15 |
Got my alternator off, and intake loose. Found out that the alternator bracket I got won't work with a long pump, and no accessory hole heads.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 ![]() |
#16 |
Theres no way the bolt can come off with the timing cover on. The PO must have dropped it in the pan. If the pan gasket was leaking in the front around the timing cover he must have pulled the cover for some reason without pulling the pan. How about a close up pic of the bolt?
#17 | |
Firedemon , please post a pic of that bolt before you tear the front of the Engine apart. Wildcard |
#18 | |
#19 |
What did I do today? I'm still doing it. It's only 1:30, I came in to eat
![]() On my '72 I have it taken down to the steering knuckles on what started as a frozen caliper/rotor replacement. I decided it was time for full drive axle serving, so spindles are off to remove, clean, spindle bearings, pack, and put new seals in. Both calipers and rotors are new. Bearings were fine. I have longer hoses (later c20) and 4" lift springs/shocks to put on while I'm at it. I've also seen guys searching for backing plates with little success, so I took those off, got them down to clean bare metal, put some rust converter on (just because), etch primed, and painted them up. Time to go pack the bearings and get brakes done. I'm glad I ate lunch first. Trying to cut out greasy food from my diet. Hopefully I'll get front springs swapped, too. Gotta paint the shocks, though.
#20 |
#21 |
#22 |
RAT1968 '68 Cab/'71 Parts
Bought a set of black plates for RAT's '71 front clip and roll pan.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#23 |
Tranny pan trouble. Tranny pan was leaking. Bought a gasket with filter. Jack up the truck, drain the pan, removed the 11 bolts & the trouble began. The two rear bolts I could not get to. I had two V two slots on the side of the tranny mount. Then the pan would not come on the rear. I had to jack up the rear of the tranny to release the pan, Tranny bolts had to be remove to do this. I have a 71 GMC> Why do I have this problem ? Anyone else run into this. I wonder if my Rear tranny mount is collapsing.
#24 |
Boy, that musta made some racket?
#25 |
